Sysprogs forums › Forums › VisualGDB › Unexpected endianess
- This topic has 3 replies, 2 voices, and was last updated 2 years, 11 months ago by
April 8, 2023 at 04:26 #34097
arcane
ParticipantHello,
I’m trying to understand where this error message is from ”unexpected endianess error: flag 104”. This occurs when im trying to flash my STM processor
I have not added anything else besides ST drivers to my VisualGDB project. Everything is from the base generation of building the project from a .ioc file
Any debugging ideas?
April 8, 2023 at 09:07 #34098support
- Please make sure the steps do not involve any 3rd-party code as we will not be able to review it. If the problem only happens with a specific project, please make sure you can reproduce it on a clean project created from scratch. See this page for more information and detailed examples.
April 9, 2023 at 08:33 #34099arcane
ParticipantSolved it, apparently I had tinkered with the VisualGDB Project properties when looking through my git logs I found the problem. The makefile settings was set to a static library, once changed back to Executable it worked.
A little too hasty on the forum post from my side, thanks for the debugging assistance on looking thru the projects source control and settings.
April 9, 2023 at 12:51 #34102support
Good to know it works. Using git, or taking brief notes of the settings you change, could indeed save lots of time tracking down such issues.
