Sysprogs forums › Forums › VisualGDB › undefined reference to 'end' _sbrk
- This topic has 8 replies, 2 voices, and was last updated 4 years ago by
February 13, 2022 at 23:44 #32191
jasonkelly214
ParticipantI’ve searched for an answer on this for a while but I’m still not having success. I ran into this first trying to call malloc, and I didn’t really need malloc that bad so I moved on. But now I’m running into it calling snprintf().
cmake project for ATSAM, using ninja, arm toolchain gcc 10.3.1, gdb 10.2.90. I’m using the default library, not newlib-nano (at least it says default).
I’ve also seen some support comments saying to manually specify –specs=nosys.specs with LDFLAGS but as this is a sysprogs toolchain shouldn’t that already be in place?
Is that this line from the toolchain.cmake: set(_ldflags ${_ldflags} “${BSP_CONFIGURATION_com.sysprogs.toolchainoptions.arm.libctype}” “${BSP_CONFIGURATION_com.sysprogs.toolchainoptions.arm.syscallspecs}”)
February 14, 2022 at 08:05 #32197support
February 15, 2022 at 21:46 #32202jasonkelly214
ParticipantLaunch visual studio, click “continue without code”.
File -> New -> VisualGDB Project
Embedded Project Wizard. Click Add
Embedded application, Advanced CMKake, C99
NEXT
Select ARM in C:\SysGCC\arm-eabi
ATSAME51J18A
Execute from FLASH, library default, Implementations for _sbrk(), etc “minimal (no semihosting)”
NEXT
Empty project
NEXT
OpenOCD, CMIS-DAP SWD programmer, target/atsame5x.cfg, SWD, Program FLASH memory always, reset before programming.
FINISH
Add new C file to project named main.c with main() function.
Project builds successfully.
Include <string.h>, add snprintf() function, error undefined reference to “end”. “could not open project\build\VisualGDB\Debug\sbrk.c, that file path might have been parsed incorrectly”.
You must be logged in to view attached files.February 15, 2022 at 21:48 #32207jasonkelly214
ParticipantI’m still in my evaluation period and this is my first project with visualgdb. I don’t think I selected anything that would cause this error but please do let me know.
You must be logged in to view attached files.February 16, 2022 at 08:39 #32225support
KeymasterThanks for the detailed repro steps. It looks like you are targeting a device from an Atmel START SDK that you have previously imported into VisualGDB. This issue could be a bug of this specific SDK, or a glitch in our importing logic.
Please try deleting the imported SDK (its location is shown at the bottom of the Device Selection page in the wizard) and importing it again. If the problem persists, please upload original SDK archive in a file sharing service and post a link here, so that we could recheck if our importing logic is handling it correctly.
February 17, 2022 at 00:01 #32234jasonkelly214
ParticipantI know you said to upload the original, but I’m not sure what all was in it. I just generated a new atmel start sdk from start.atmel.com and created a new visualgdb project with the same steps I did above and I got the same results.
I noticed the warning “manually-specified variables were not used by the project: LOCALAPPDATA”. I suspect that could be relevant since that is the location of the Atmel start file?
Shared files location: C:\Users\jason\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.atstart.ATSAME51J18A
Here is the .atzip from the start configurator: https://www.dropbox.com/s/iwasymqxcnljno8/My%20Project4.atzip?dl=0
I know there were some settings in the advanced section about path mapping, none of which I changed. But in the error output it shows a path using both a forward and back slash; I assumed this was ok. Screenshot attached.
You must be logged in to view attached files.February 17, 2022 at 09:45 #32242support
KeymasterThanks, we have reproduced the issue. It is triggered by selecting “Empty project” on the Sample Selection page of the wizard. This option assumes that you are familiar with the underlying SDK and can add all the necessary files manually.
Please try selecting “Default project” instead – it will import a sample project from the SDK itself, that should include all the necessary files.
That said, with this specified SDK, you will need to manually reference the AtmelStart framework via VisualGDB Project Properties -> Embedded Frameworks. We will address this in the next VisualGDB version; until then, please reference the framework manually after creating a project.
February 17, 2022 at 10:31 #32243jasonkelly214
ParticipantOk I see.
Even with a default project it doesn’t pull in the ASF files; I still had to follow your step of including them from the project properties.
I went back and forth on using AFS because I find it cumbersome to navigate and often full of bugs, especially relating to setting the clocks. I thought that by importing the atmel start sdk the various makefile settings would be included such that I could create my project with whatever was needed for the project. I didn’t understand sbrk or that it wasn’t a hardware mapping but was a “utility”.
It seems sufficient to pull in utils_syscalls.c from the asf files.
I have it working now, thanks!
February 17, 2022 at 10:45 #32248support
KeymasterGood to know it works. In general, the “empty project” option simply strips all sources from original project template. It cannot automatically determine which of these sources would be needed in each specific scenario, so it may indeed involve some trial-and-error to figure that out. Having a working project based on the full template as a comparison could be a good reference point.
