Sysprogs forums › Forums › VisualGDB › Unable to use WSL
- This topic has 4 replies, 2 voices, and was last updated 6 years, 6 months ago by
j.jemine.
March 30, 2020 at 13:13 #27785
j.jemine
I’m trying to compile with WSL and I face the following problem:
Exception details:
VisualGDB version: 5.5.4.3540
------------------ System.Exception ------------------
System.Exception: Failed to build Linux subsystem launcher. Please check that the Linux subsystem is installed and contains gcc. ---> System.Exception: gcc exited with code 2
at q4.b()
at q4.b()
at cj2.g.m1(CommandLineAction c, CommandFlags b, Boolean a)
at cj2.g..ctor(q4 b, CommandLineAction d, CommandFlags c, m22 a, Boolean e)
at cj2.b_2(m22 a, String d, String b, String f, ExpandedEnvironment e, CommandFlags c)
at vi2.l1(String a, String b, zr& c)
at kk1.l(og a)
at kk1.n1(og a, String f, String c, String b, s1 e, Boolean d)
at jv1.c1(og d, String f, String e, String c, s1 b, Boolean a)
at nv1.a(String a)
at nv1.Run()
at VisualGDB.Common_GUI.WPF.AdvancedToolchainSelectionControl.Controller.ImportToolchain(BasicToolchainProviderBase provider)
trace=[q4.b:309, cj2+g.m1:578, cj2+g..ctor:98, cj2.b_2:36, vi2.l1:0, kk1.l:2, kk1.n1:31, jv1.c1:46, nv1.a:95, nv1.Run:0, VisualGDB.Common_GUI.WPF.AdvancedToolchainSelectionControl+Controller.ImportToolchain:0]
------------------ Inner exception ------------------
at q4.b()
trace=[q4.b:269]
I’ve tried with both legacy WSL and the Alpine distribution with the same result.
I’m using WSL 1 (sadly, our IT department won’t let us upgrade to 2 yet)
I have already checked https://sysprogs.com/w/forums/topic/unable-to-connect-to-wsl-on-windows-10-1903-build/
I have gcc installed (5.4.0) and C: mounted in the default /mnt/c.
Thanks.
March 30, 2020 at 15:31 #27786j.jemine
ParticipantHere is the output of the compilation command
C:\Users\jj>C:\windows\system32\wsl.exe -- gcc -std=gnu99 "/mnt/c/Program Files (x86)/Sysprogs/VisualGDB/TargetTools/LinuxAppLauncher.c" -o /tmp/LinuxAppLauncher-v3 -lutil /bin/bash: --: invalid option Usage: /bin/bash [GNU long option] [option] ... /bin/bash [GNU long option] [option] script-file ... GNU long options: --debug --debugger --dump-po-strings --dump-strings --help --init-file --login --noediting --noprofile --norc --posix --rcfile --restricted --verbose --version Shell options: -ilrsD or -c command or -O shopt_option (invocation only) -abefhkmnptuvxBCHP or -o option-
This reply was modified 6 years, 6 months ago by
j.jemine.
March 30, 2020 at 15:40 #27788j.jemine
ParticipantOh I see, it’s because we’re still running on Windows 1803, and the arguments to WSL have changed in 1903.
For this particular command, it just works if I remove the “–“. I don’t know if that would fix every use case of WSL by VisualGDB ?
Could VisualGDB detect the version of wsl.exe and use “–” only when required ?
Thanks.
March 30, 2020 at 18:36 #27789support
KeymasterNo problem, please try this build: VisualGDB-5.5.4.3559.msi
It will automatically detect the old Windows 10 builds and will revert to using the old bash.exe syntax when targeting WSL.
March 30, 2020 at 21:52 #27790 -
