Unable to start VisualKernel debug session over COM port
Sysprogs forums Forums VisualKernel Unable to start VisualKernel debug session over COM port
  • #6307
    mcmordie
    I have an ARM target and am debugging from VisualKernel on a Windows 7 laptop with a x86 VM host for kernel compilation.  Symbols load correctly and verify as the correct version.  I am able to start kgdb on the serial console of the target using the following command:
    echo g > /proc/sysrq-trigger
    However, when I launch the debug session from VisualKernel, it times out waiting for the target-select remote :55145 command to complete.
    Is this target-select command right for a COM port debug session?  Do I guess right that you are redirecting from a TCP port to the COM1 that my device is attached to?  If so, is there a way to test that this is working?
    Any other thoughts on why the debug session won’t start?  I was able to do this with a trial version some months back– everything worked fine.
    I have “Kernel connection mode” = “Use a built-in Kernel Debugger (KGDB) via a COM port”.  Other settings for the com port on the linux and windows sides look good.  I have verified using the console that I get the starting KGDB message.
    Best,
    Dave
    #6318
    Please double-check the COM port settings in the Windows Device Manager and ensure that the speed and the parity settings match the settings on the Linux side.
