Sysprogs forums › Forums › VisualGDB › Unable to connect to WSL on Windows 10 1903 build
- This topic has 7 replies, 2 voices, and was last updated 6 years, 9 months ago by
June 10, 2019 at 15:09 #25103
winest
ParticipantSteps to reproduce:
- In ViusalStudio 2019 startup wizard, create a Linux project
- Select “Import a project”, and thenselect “Import a CMake project”, click Next
- Select “Use the Windows 10 Linux Subsystem”, click Next
- An error message displayed at first step, “Toolchain test failed: Failed to build Linux subsystem Launcher. Please check that the Linux subsystem is installed and contains gcc.”
Only one Linux Subsystem OS is installed, the registry value in HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Lxss is correct and I can use ssh to connect to my WSL.
Visual Studio Version: Visual Studio Enterprise 2019 16.1.2
Windows Version: Windows 10 1903(18362.116)
Linux Subsystem OS: Ubuntu 18.04 downloaded from Windows Store
VisualGDB version: 5.4.106.3190
System.Exception: Failed to build Linux subsystem launcher. Please check that the Linux subsystem is installed and contains gcc.
at aj.l.c1()
at aj.l.n(CommandLineAction a, CommandFlags b, Boolean c)
at aj.l..ctor(CommandLineAction c, CommandFlags b, qh a, Boolean d)
at aj.r_4(qh b, String f, String e, String d, ExpandedEnvironment c, CommandFlags a)
at y52.g1(Int32& e, String d, String c, String g, ModifiedEnvirionment b, Int32 i, Boolean a, CommandFlags h, h91 f)
at y52.g(String b, String e, String c, ModifiedEnvirionment f, Int32 d, Boolean a)
at zx.a(s32 a)
at VisualGDB.Common_GUI.WPF.ItemizedProgressWindow.<>c__DisplayClass2_2`1.<RunAction>b__0()June 10, 2019 at 16:32 #25104support
As the message suggests, please double-check that your WSL installation has gcc installed. You can check it by running “gcc -v” from the bash prompt.
June 11, 2019 at 07:53 #25107winest
ParticipantOf course I have already installed all development tools and is able to build my c++ projects by using ssh.
Output of “gcc -v”:
Using built-in specs.COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/5/lto-wrapper
Target: x86_64-linux-gnu
Configured with: ../src/configure -v –with-pkgversion=’Ubuntu 5.5.0-12ubuntu1′ –with-bugurl=file:///usr/share/doc/gcc-5/README.Bugs –enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++ –prefix=/usr –program-suffix=-5 –enable-shared –enable-linker-build-id –libexecdir=/usr/lib –without-included-gettext –enable-threads=posix –libdir=/usr/lib –enable-nls –with-sysroot=/ –enable-clocale=gnu –enable-libstdcxx-debug –enable-libstdcxx-time=yes –with-default-libstdcxx-abi=new –enable-gnu-unique-object –disable-vtable-verify –enable-libmpx –enable-plugin –enable-default-pie –with-system-zlib –enable-objc-gc –enable-multiarch –disable-werror –with-arch-32=i686 –with-abi=m64 –with-multilib-list=m32,m64,mx32 –enable-multilib –with-tune=generic –enable-checking=release –build=x86_64-linux-gnu –host=x86_64-linux-gnu –target=x86_64-linux-gnu
Thread model: posix
gcc version 5.5.0 20171010 (Ubuntu 5.5.0-12ubuntu1)June 11, 2019 at 23:44 #25121support
KeymasterThanks for confirming this. We have just retested VisualGDB with WSL on Windows 10 build 1903, however we could not reproduce the issue you described.
Please try running this build: VisualGDB-5.4.106.3193.msi
Then enable the VisualGDB Diagnostics Console, reproduce the problem and check the diagnostic output for the command line used by build the app launcher (search for LinuxAppLauncher.c). Then try running the command line manually and see if GCC reports any errors. Once you pinpoint a specific error, please let us know and we will try to add a workaround for this.
June 12, 2019 at 02:56 #25122winest
ParticipantHi, I guess I know the problem. The root cause is VisualGDB assume Windows drives are mounted at default path (/mnt/c/VisualGDB, for example) while some people like me will change mounting path to other places(/c/VisualGDB, for example) based on the suggestion fromĀ https://devblogs.microsoft.com/commandline/automatically-configuring-wsl/
Hope VisualGDB can implement the fix which read the setting from /etc/wsl.conf
BTW, another error was output saying that “Loading machine index from C:\Users\winest\.vagrant.d\data\machine-index\index…
failed to load vagrant VM list: Could not find a part of the path “.I don’t know whether it will affect anything or it’s just a warning.
Key error:
C:\Users\winest>C:\WINDOWS\system32\bash.exe -c “gcc -std=gnu99 \”/mnt/e/VisualGDB/TargetTools/LinuxAppLauncher.c\” -o /tmp/LinuxAppLauncher-v2 -lutil”
gcc: error: /mnt/e/VisualGDB/TargetTools/LinuxAppLauncher.c: No such file or directory
at VisualGDB.Common_GUI.WPF.ItemizedProgressWindow.<>c__DisplayClass2_2`1.<RunAction>b__0()Full log:
Initializing assemblies: 14 msec
Registering factories: 117 msec
Initializing VisualGDB 5.4.106.3193
Checking fonts/colors: 73 msec
Level 2 initialization: 732 msec
failed to load vagrant VM list: Could not find a part of the path ‘C:\Users\winest\.vagrant.d\data\machine-index\index’.
—————— System.IO.DirectoryNotFoundException ——————
System.IO.DirectoryNotFoundException: Could not find a part of the path ‘C:\Users\winest\.vagrant.d\data\machine-index\index’.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize, Boolean checkHost)
at System.IO.File.InternalReadAllText(String path, Encoding encoding, Boolean checkHost)
at System.IO.File.ReadAllText(String path)
at hy1.e()
at hy1.m()
Loading Linux toolchain list for winest@localhost:50022 (SSH)
Creating toolchain controller: initial selection (registry)
SelectToolchainByKey(com.sysprogs.toolchain.default-gcc )
Loading Linux toolchain list for (Windows 10 Linux subsystem)
Committing LinuxTargetPage…
Testing project settings…
Running toolchain tester…
Unexpected exception: Failed to build Linux subsystem launcher. Please check that the Linux subsystem is installed and contains gcc.
at wr.q.i1()
at wr.q.n(CommandLineAction b, CommandFlags c, Boolean a)
at wr.q..ctor(CommandLineAction d, CommandFlags b, y42 a, Boolean c)
at wr.g_2(y42 f, String e, String c, String a, ExpandedEnvironment b, CommandFlags d)
at hi2.m2(Int32& a, String b, String h, String c, ModifiedEnvirionment e, Int32 g, Boolean i, CommandFlags d, co2 f)
at hi2.k2(String b, String e, String f, ModifiedEnvirionment a, Int32 d, Boolean c)
at va2.r(du a)June 12, 2019 at 19:40 #25126support
KeymasterGood to know you found the root cause.
As the issue is triggered by a relatively rare setting, we would only be able to support it if there is an easy way to extract the path mappings from the WSL configuration file and if it’s requested by a user with an active support period (sorry, we could not find any orders associated with your email).
The vagrant warning in the diagnostics console can be safely ignored – it comes from VisualGDB trying to locate virtual machines managed by the Vagrant tool and will indeed appear if you don’t have the tool installed.
June 13, 2019 at 04:29 #25127winest
ParticipantHi, it’s a very simple ini file. So you can extract config by the following command:
C:\Windows\System32\bash.exe -c “awk -F = ‘/^root/ {gsub(/^[ \t]/, \”\”, \$2); print \$2}’ /etc/wsl.conf”
June 13, 2019 at 17:18 #25129support
KeymasterThanks for the update. It looks like we should be able to support it once requested by a user with an active technical support.
