Unable to chose source directory (permission denied)
Sysprogs forums › Forums › VisualGDB › Unable to chose source directory (permission denied)
  • #543
    kbzowski
    I am running VisualGDBBuildServer on Linux server with user privileges. During importing project, in a step when I need to specify Linux source directory, window with directories tree is always set to /. But I have not got rights to see list of directories in /home so I need to type a whole path by hand. Can you change a default behavior of VisualGDBBuildServer to open home directory instead in case when it is running with user rights?
    If I had put some path in text box with “Source directory” label and click “Select Directory” button – it would be nice to open directories tree in this place.
    Thanks in advance
    K.
    #2320
    ket
    Thank you for your suggestions. We have made a note of it for the next version’s feature list. Please also consider switching from using the VisualGDBBuildServer to using SSH, which became supported since VisualGDB 3.0.
