Two problems with VirtualKD: VirtualBox & Windows 10
Sysprogs forums Forums VisualDDK/VirtualKD discussion Two problems with VirtualKD: VirtualBox & Windows 10
  • #11029
    syzop
    First of all, thank you for creating VirtualKD. Kernel debugging is so much faster now than ‘traditional serial’.
    I had to overcome two hurdles to get things working, however, so hopefully these can be fixed or better documented for other users:
    On the HOST side:
    • The latest version of Virtual Box (5.1.20) does not work with VirtualBoxIntegration.exe. I had to downgrade to VirtualBox 5.0.38.
    On the TARGET VM:
    • On Windows 10 after installing target\vminstall.exe I also had to run: BCDEDIT /dbgsettings serial
    Regards,
    Bram
    #11249
    snowkoan
    Thank you for the second tip! I’ve been puzzling over that for a few days now.
