Trying to get RTC working and HAL_GetTick() doesn't seem to be incrementing
Sysprogs forums › Forums › VisualGDB › Trying to get RTC working and HAL_GetTick() doesn't seem to be incrementing
  • #29425
    GeneM
    I’m very much still learning the STM32 and all my work starts so far starts with examples.  I can run the  VisualGDB NewEmbedded Project -> STM32CubeMX Samples -> STM32F413ZH-Nucleo -> Examples -> RTC -> RTC_Calendar and it seems to work fine.  But when I put it in a larger app that started from the VisualGDB UART tutorial, it doesn’t.  I think I’ve tracked it down to the RTC_EnterInitMode subroutine in stm32F4xx_hal_rtc.c.  It looks like HAL_GetTick isn’t incrementing the tickstart value:
    tickstart = HAL_GetTick();
    /* Wait till RTC is in INIT state and if Time out is reached exit */
    while((hrtc->Instance->ISR & RTC_ISR_INITF) == (uint32_t)RESET)
    if((HAL_GetTick() - tickstart ) > RTC_TIMEOUT_VALUE)
    return HAL_TIMEOUT;
    I’ve been trying to figure out what the STM32 HAL RTC example might be doing to make HAL_GetTick work but I’m not doing in the app I wrote from the VisualGDB UART example.  I don’t know if it makes any difference but my app is C++ and the HAL RTC example is straight C.  My code does have a SysTick_Handler in main.cpp as shown below.  The HAL example seems to bury the SysTick_Handler in various other files but it does seem to do the same thing.
    void SysTick_Handler(void)
    HAL_IncTick();
    HAL_SYSTICK_IRQHandler();
    Any suggestions will be greatly appreciated.
    #29426
    This looks like an issue specific to the STM32 microcontrollers and not something VisualGDB-specific. Please consider posting STM32-specific questions in the STM32 community instead.
