Sysprogs forums › Forums › Other tools & products › Toolchain (Win) for Raspberry (Jessie) doesn't search at OpenCV lib path given
- This topic has 0 replies, 1 voice, and was last updated 8 years, 10 months ago by
demonbots.
Viewing 1 post (of 1 total)
May 20, 2017 at 17:33 #11262
demonbots
ParticipantHi, I am cross compiling on Windows (Eclipse) for the target Raspberry Pi (Jessie). I have used the toolchain (raspberry-gcc-4.9.2-r4) from http://gnutoolchains.com/raspberry/. I was able to successfully compile and run a simple "Hello World" program on Windows and run it on the Pi. However, I ran into some trouble when I tried to compile a program that uses OpenCV3200 as an external lib. I compiled and installed OpenCV3200 on the raspberry pi and then synchronised Sysroot over to my windows host machine. Now upon trying to build, I am able to compile the program without errors however the linker fails with the error saying its unable to find the opencv libs. For some reason, the linker is ignoring the Lib Path that I pass to it with the -L option and instead uses different library paths. Please see the output of the compiler and linker below. make all 'Building file: ../bas.cpp' 'Invoking: Cross G++ Compiler' arm-linux-gnueabihf-g++ -I"C:\SysGCC\Raspberry\arm-linux-gnueabihf\sysroot\usr\local\include" -O0 -g3 -Wall -c -fmessage-length=0 -v -MMD -MP -MF"bas.d" -MT"bas.o" -o "bas.o" "../bas.cpp" Using built-in specs. COLLECT_GCC=arm-linux-gnueabihf-g++ Target: arm-linux-gnueabihf Configured with: ../gcc-4.9.2/src/configure --enable-win32-registry=SysGCC-arm-linux-gnueabihf-4.9.2 --prefix /q/gnu/linux/raspberry-jessie/out/ --disable-nls --without-libiconv-prefix --with-sysroot=/q/gnu/linux/raspberry-jessie/out/arm-linux-gnueabihf/sysroot --enable-languages=c,c++ --enable-shared --enable-linker-build-id --without-included-gettext --enable-threads=posix --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libitm --disable-libquadmath --with-arch-directory=arm --disable-sjlj-exceptions --with-arch=armv6 --with-fpu=vfp --with-float=hard --enable-checking=release --target arm-linux-gnueabihf Thread model: posix gcc version 4.9.2 (GCC) COLLECT_GCC_OPTIONS='-I' 'C:\SysGCC\Raspberry\arm-linux-gnueabihf\sysroot\usr\local\include' '-O0' '-g3' '-Wall' '-c' '-fmessage-length=0' '-v' '-MMD' '-MP' '-MF' 'bas.d' '-MT' 'bas.o' '-o' 'bas.o' '-shared-libgcc' '-march=armv6' '-mfloat-abi=hard' '-mfpu=vfp' '-mtls-dialect=gnu' c:/sysgcc/raspberry/bin/../libexec/gcc/arm-linux-gnueabihf/4.9/cc1plus.exe -quiet -v -I C:\SysGCC\Raspberry\arm-linux-gnueabihf\sysroot\usr\local\include -imultilib . -imultiarch arm-linux-gnueabihf -iprefix c:\sysgcc\raspberry\bin\../lib/gcc/arm-linux-gnueabihf/4.9/ -isysroot c:\sysgcc\raspberry\bin\../arm-linux-gnueabihf/sysroot -MMD bas.d -MF bas.d -MP -MT bas.o -dD -D_GNU_SOURCE ../bas.cpp -quiet -dumpbase bas.cpp -march=armv6 -mfloat-abi=hard -mfpu=vfp -mtls-dialect=gnu -auxbase-strip bas.o -g3 -O0 -Wall -version -fmessage-length=0 -o C:\Users\JDas\AppData\Local\Temp\ccM8oBVP.s GNU C++ (GCC) version 4.9.2 (arm-linux-gnueabihf) compiled by GNU C version 4.8.1, GMP version 4.2.4, MPFR version 2.4.1, MPC version 0.8 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\sysgcc\raspberry\bin\../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/include/arm-linux-gnueabihf/c++/4.9/arm-linux-gnueabihf" ignoring duplicate directory "c:/sysgcc/raspberry/lib/gcc/../../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/include/c++/4.9" ignoring nonexistent directory "C:/MinGW/msys/1.0/include/arm-linux-gnueabihf/c++/4.9/." ignoring nonexistent directory "c:/sysgcc/raspberry/lib/gcc/../../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/include/arm-linux-gnueabihf/c++/4.9" ignoring duplicate directory "c:/sysgcc/raspberry/lib/gcc/../../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/include/c++/4.9/backward" ignoring duplicate directory "c:/sysgcc/raspberry/lib/gcc/../../lib/gcc/arm-linux-gnueabihf/4.9/include" ignoring nonexistent directory "c:\sysgcc\raspberry\bin\../arm-linux-gnueabihf/sysroot/usr/include/arm-linux-gnueabihf/arm-linux-gnueabihf" ignoring duplicate directory "c:/sysgcc/raspberry/lib/gcc/../../lib/gcc/arm-linux-gnueabihf/4.9/include-fixed" ignoring duplicate directory "c:/sysgcc/raspberry/lib/gcc/../../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/include" ignoring duplicate directory "c:\sysgcc\raspberry\bin\../arm-linux-gnueabihf/sysroot/usr/include/arm-linux-gnueabihf" #include "..." search starts here: #include <...> search starts here: C:\SysGCC\Raspberry\arm-linux-gnueabihf\sysroot\usr\local\include c:\sysgcc\raspberry\bin\../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/include/c++/4.9 c:\sysgcc\raspberry\bin\../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/include/c++/4.9/backward c:\sysgcc\raspberry\bin\../lib/gcc/arm-linux-gnueabihf/4.9/include c:\sysgcc\raspberry\bin\../lib/gcc/arm-linux-gnueabihf/4.9/include-fixed c:\sysgcc\raspberry\bin\../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/include c:\sysgcc\raspberry\bin\../arm-linux-gnueabihf/sysroot/usr/include/arm-linux-gnueabihf c:\sysgcc\raspberry\bin\../arm-linux-gnueabihf/sysroot/usr/include End of search list. GNU C++ (GCC) version 4.9.2 (arm-linux-gnueabihf) compiled by GNU C version 4.8.1, GMP version 4.2.4, MPFR version 2.4.1, MPC version 0.8 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: 77a52a28e20292d776f27f30cc5b625f COLLECT_GCC_OPTIONS='-I' 'C:\SysGCC\Raspberry\arm-linux-gnueabihf\sysroot\usr\local\include' '-O0' '-g3' '-Wall' '-c' '-fmessage-length=0' '-v' '-MMD' '-MP' '-MF' 'bas.d' '-MT' 'bas.o' '-o' 'bas.o' '-shared-libgcc' '-march=armv6' '-mfloat-abi=hard' '-mfpu=vfp' '-mtls-dialect=gnu' c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/bin/as.exe -v -I C:\SysGCC\Raspberry\arm-linux-gnueabihf\sysroot\usr\local\include -march=armv6 -mfloat-abi=hard -mfpu=vfp -meabi=5 -o bas.o C:\Users\JDas\AppData\Local\Temp\ccM8oBVP.s GNU assembler version 2.25 (arm-linux-gnueabihf) using BFD version (GNU Binutils) 2.25 COMPILER_PATH=c:/sysgcc/raspberry/bin/../libexec/gcc/arm-linux-gnueabihf/4.9/;c:/sysgcc/raspberry/bin/../libexec/gcc/arm-linux-gnueabihf/;c:/sysgcc/raspberry/bin/../libexec/gcc/;c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/bin/ LIBRARY_PATH=c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/4.9/;c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/;c:/sysgcc/raspberry/bin/../lib/gcc/;c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/lib/;c:/sysgcc/raspberry/bin/../arm-linux-gnueabihf/sysroot/lib/arm-linux-gnueabihf/;c:/sysgcc/raspberry/bin/../arm-linux-gnueabihf/sysroot/lib/;c:/sysgcc/raspberry/bin/../arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/;c:/sysgcc/raspberry/bin/../arm-linux-gnueabihf/sysroot/usr/lib/ COLLECT_GCC_OPTIONS='-I' 'C:\SysGCC\Raspberry\arm-linux-gnueabihf\sysroot\usr\local\include' '-O0' '-g3' '-Wall' '-c' '-fmessage-length=0' '-v' '-MMD' '-MP' '-MF' 'bas.d' '-MT' 'bas.o' '-o' 'bas.o' '-shared-libgcc' '-march=armv6' '-mfloat-abi=hard' '-mfpu=vfp' '-mtls-dialect=gnu' 'Finished building: ../bas.cpp' ' ' 'Building target: Basic' 'Invoking: Cross G++ Linker' arm-linux-gnueabihf-g++ -L"C:\SysGCC\Raspberry\arm-linux-gnueabihf\sysroot\usr\local\lib" -o "Basic" ./bas.o -llibopencv_calib3d -llibopencv_core -llibopencv_highgui -llibopencv_imgcodecs -llibopencv_imgproc -llibopencv_video -llibopencv_videoio -llibopencv_videostab c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/bin/ld.exe: cannot find -llibopencv_calib3d c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/bin/ld.exe: cannot find -llibopencv_core c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/bin/ld.exe: cannot find -llibopencv_highgui c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/bin/ld.exe: cannot find -llibopencv_imgcodecs c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/bin/ld.exe: cannot find -llibopencv_imgproc c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/bin/ld.exe: cannot find -llibopencv_video c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/bin/ld.exe: cannot find -llibopencv_videoio c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/4.9/../../../../arm-linux-gnueabihf/bin/ld.exe: cannot find -llibopencv_videostab collect2.exe: error: ld returned 1 exit status make: *** [Basic] Error 1 I updated the ld.so.config file but that didn't help either. So now I am a bit unsure of what else I can do to get the linker to look at the correct directory. Any help would be really appreciated. Thanks in advance Regards JD
