tbreak main not work, Debugger not work
Sysprogs forums › Forums › VisualGDB › tbreak main not work, Debugger not work
  • #25310
    ExtSol
    I tried to add break point to main with parameter, but not work. How can i stop debugging when reach main?
    In VS 2017 and 2019 both, do not work debugging.
    Please see de pictures, and i share my project at this link:
    https://drive.google.com/open?id=1c5lWZ_0vl7CMaqzAYuhMipdB8AryRcLf
    • This topic was modified 7 years, 2 months ago by ExtSol.
    #25314
    ExtSol
    C:\SysGCC\arm-eabi\bin\arm-eabi-gdb.exe –interpreter mi “C:\Users\ExtSol\Desktop\VisualGDBTemplate\VisualGDB\Debug\VisualGDBTemplate”
    [ 0 ms] -gdb-version
    [ 34 ms] =thread-group-added,id=”i1″
    [ 34 ms] ~”GNU gdb (GDB) 8.0.1\n”
    [ 34 ms] ~”Copyright (C) 2017 Free Software Foundation, Inc.\n”
    [ 34 ms] ~”License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html&gt;\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law. Type \”show copying\”\nand \”show warranty\” for details.\n”
    [ 35 ms] ~”This GDB was configured as \”–host=i686-w64-mingw32 –target=arm-eabi\”.\nType \”show configuration\” for configuration details.”
    [ 35 ms] ~”\nFor bug reporting instructions, please see:\n”
    [ 35 ms] ~”<http://www.gnu.org/software/gdb/bugs/&gt;.\n”
    [ 35 ms] ~”Find the GDB manual and other documentation resources online at:\n<http://www.gnu.org/software/gdb/documentation/&gt;.\n”
    [ 35 ms] ~”For help, type \”help\”.\n”
    [ 35 ms] ~”Type \”apropos word\” to search for commands related to \”word\”…\n”
    [ 35 ms] ~”Reading symbols from C:\\Users\\ExtSol\\Desktop\\VisualGDBTemplate\\VisualGDB\\Debug\\VisualGDBTemplate…”
    [ 35 ms] ~”done.\n”
    [ 36 ms] ~”GNU gdb (GDB) 8.0.1\n”
    [ 36 ms] ~”Copyright (C) 2017 Free Software Foundation, Inc.\n”
    [ 36 ms] ~”License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html&gt;\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law. Type \”show copying\”\nand \”show warranty\” for details.\n”
    [ 36 ms] ~”This GDB was configured as \”–host=i686-w64-mingw32 –target=arm-eabi\”.\nType \”show configuration\” for configuration details.”
    [ 36 ms] ~”\nFor bug reporting instructions, please see:\n”
    [ 36 ms] ~”<http://www.gnu.org/software/gdb/bugs/&gt;.\n”
    [ 36 ms] ~”Find the GDB manual and other documentation resources online at:\n<http://www.gnu.org/software/gdb/documentation/&gt;.\n”
    [ 36 ms] ~”For help, type \”help\”.\n”
    [ 36 ms] ~”Type \”apropos word\” to search for commands related to \”word\”.\n”
    [ 36 ms] ^done
    [ 36 ms] -list-features
    [ 37 ms] ^done,features=[“frozen-varobjs”,”pending-breakpoints”,”thread-info”,”data-read-memory-bytes”,”breakpoint-notifications”,”ada-task-info”,”language-option”,”info-gdb-mi-command”,”undefined-command-error-code”,”exec-run-start-option”]
    [ 37 ms] -gdb-set disassembly-flavor intel
    [ 37 ms] ^error,msg=”No symbol \”disassembly\” in current context.”
    [ 37 ms] -gdb-set print demangle off
    [ 37 ms] ^done
    [ 38 ms] set remotetimeout 60
    [ 47 ms] &”set remotetimeout 60\n”
    [ 47 ms] =cmd-param-changed,param=”remotetimeout”,value=”60″
    [ 47 ms] ^done
    [ 47 ms] target remote :49841
    [ 47 ms] &”target remote :49841\n”
    [ 53 ms] ~”Remote debugging using :49841\n”
    [ 59 ms] =thread-group-started,id=”i1″,pid=”42000″
    [ 59 ms] =thread-created,id=”1″,group-id=”i1″
    [ 61 ms] ~”Reset_Handler () at C:/Users/ExtSol/AppData/Local/VisualGDB/EmbeddedBSPs/arm-eabi/com.sysprogs.arm.stm32/STM32F1xxxx/StartupFiles/startup_stm32f103xb.c:572\n”
    [ 61 ms] ~”572\t\tfor (pSource = &_sidata, pDest = &_sdata; pDest != &_edata; pSource++, pDest++)\n”
    [ 61 ms] *stopped,frame={addr=”0x080001dc”,func=”Reset_Handler”,args=[],file=”C:/Users/ExtSol/AppData/Local/VisualGDB/EmbeddedBSPs/arm-eabi/com.sysprogs.arm.stm32/STM32F1xxxx/StartupFiles/startup_stm32f103xb.c”,fullname=”C:\\Users\\ExtSol\\AppData\\Local\\VisualGDB\\EmbeddedBSPs\\arm-eabi\\com.sysprogs.arm.stm32\\STM32F1xxxx\\StartupFiles\\startup_stm32f103xb.c”,line=”572″},thread-id=”1″,stopped-threads=”all”
    [ 62 ms] ^done
    [ 62 ms] info shared
    [ 71 ms] &”info shared\n”
    [ 71 ms] ~”No shared libraries loaded at this time.\n”
    [ 71 ms] ^done
    [ 71 ms] mon halt
    [ 71 ms] &”mon halt\n”
    [ 73 ms] ^done
    [ 73 ms] mon reset init
    [ 73 ms] &”mon reset init\n”
    [ 90 ms] @”target halted due to debug-request, current mode: Thread \n”
    [ 90 ms] @”xPSR: 0x01000000 pc: 0x080001dc msp: 0x20005000\n”
    [ 91 ms] ^done
    [ 91 ms] load
    [ 101 ms] &”load\n”
    [ 145 ms] ~”Loading section .isr_vector, size 0x10c lma 0x8000000\n”
    [ 145 ms] +download,{section=”.isr_vector”,section-size=”268″,total-size=”6422″}
    [ 146 ms] +download,{section=”.isr_vector”,section-sent=”268″,section-size=”268″,total-sent=”268″,total-size=”6422″}
    [ 146 ms] ~”Loading section .text, size 0x1c4 lma 0x800010c\n”
    [ 146 ms] +download,{section=”.text”,section-size=”452″,total-size=”6422″}
    [ 146 ms] ~”Loading section .init_array, size 0x4 lma 0x80002d0\n”
    [ 146 ms] +download,{section=”.init_array”,section-size=”4″,total-size=”6422″}
    [ 146 ms] ~”Loading section .fini_array, size 0x4 lma 0x80002d4\n”
    [ 146 ms] +download,{section=”.fini_array”,section-size=”4″,total-size=”6422″}
    [ 223 ms] ~”Start address 0x80001dc, load size 728\n”
    [ 223 ms] ~”Transfer rate: 5 KB/sec, 182 bytes/write.\n”
    [ 223 ms] ^done
    [ 224 ms] -data-evaluate-expression “sizeof(void *)”
    [ 233 ms] ^done,value=”4″
    [ 233 ms] -data-evaluate-expression “sizeof(int)”
    [ 243 ms] ^done,value=”4″
    [ 243 ms] -data-evaluate-expression “sizeof(short)”
    [ 243 ms] ^done,value=”2″
    [ 243 ms] -data-evaluate-expression “sizeof(long)”
    [ 243 ms] -data-evaluate-expression “sizeof(long long)”
    [ 244 ms] ^done,value=”8″
    [ 244 ms] -data-evaluate-expression “sizeof(char)”
    [ 244 ms] ^done,value=”1″
    [ 244 ms] -data-evaluate-expression “sizeof(wchar_t)”
    [ 244 ms] ^error,msg=”No symbol \”wchar_t\” in current context.”
    [ 244 ms] -data-evaluate-expression “sizeof(float)”
    [ 244 ms] ^done,value=”4″
    [ 244 ms] -data-evaluate-expression “sizeof(double)”
    [ 244 ms] -data-evaluate-expression “sizeof(long double)”
    [ 245 ms] ^done,value=”8″
    [ 267 ms] info target
    [ 276 ms] &”info target\n”
    [ 276 ms] ~”Symbols from \”C:\\Users\\ExtSol\\Desktop\\VisualGDBTemplate\\VisualGDB\\Debug\\VisualGDBTemplate\”.\n”
    [ 276 ms] ~”Remote serial target in gdb-specific protocol:\n”
    [ 276 ms] ~”Debugging a target over a serial line.\n”
    [ 276 ms] ~”\tWhile running this, GDB does not access memory from…\n”
    [ 276 ms] ~”Local exec file:\n”
    [ 276 ms] ~”\t`C:\\Users\\ExtSol\\Desktop\\VisualGDBTemplate\\VisualGDB\\Debug\\VisualGDBTemplate’, file type elf32-littlearm.\n”
    [ 276 ms] ~”\tEntry point: 0x80001dc\n”
    [ 276 ms] ~”\t0x08000000 – 0x0800010c is .isr_vector\n”
    [ 276 ms] ~”\t0x0800010c – 0x080002d0 is .text\n”
    [ 276 ms] ~”\t0x080002d0 – 0x080002d4 is .init_array\n”
    [ 276 ms] ~”\t0x080002d4 – 0x080002d8 is .fini_array\n”
    [ 276 ms] ~”\t0x20000000 – 0x20000000 is .data\n”
    [ 276 ms] ~”\t0x20000000 – 0x20000020 is .bss\n”
    [ 276 ms] ^done
    [ 278 ms] -break-insert -f C:/Users/ExtSol/Desktop/VisualGDBTemplate/VisualGDBTemplate.c:16
    [ 290 ms] ^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x080002a8″,func=”main”,file=”VisualGDBTemplate.c”,fullname=”C:\\Users\\ExtSol\\Desktop\\VisualGDBTemplate\\VisualGDBTemplate.c”,line=”16″,thread-groups=[“i1″],times=”0″,original-location=”C:/Users/ExtSol/Desktop/VisualGDBTemplate/VisualGDBTemplate.c:16″}
    [ 290 ms] -break-after 1 0
    [ 300 ms] ^done
    [ 300 ms] info symbol 0x80002a8
    [ 300 ms] &”info symbol 0x80002a8\n”
    [ 300 ms] ~”main + 24 in section .text\n”
    [ 300 ms] ^done
    [ 300 ms] info line *0x80002a8
    [ 301 ms] &”info line *0x80002a8\n”
    [ 301 ms] ~”Line 16 of \”VisualGDBTemplate.c\” starts at address 0x80002a8 <main+24> and ends at 0x80002ae <main+30>.\n”
    [ 301 ms] ^done
    [ 301 ms] -file-list-exec-source-files
    [ 302 ms] ^done,files=[{file=”C:/Users/ExtSol/AppData/Local/VisualGDB/EmbeddedBSPs/arm-eabi/com.sysprogs.arm.stm32/STM32F1xxxx/StartupFiles/startup_stm32f103xb.c”,fullname=”C:\\Users\\ExtSol\\AppData\\Local\\VisualGDB\\EmbeddedBSPs\\arm-eabi\\com.sysprogs.arm.stm32\\STM32F1xxxx\\StartupFiles\\startup_stm32f103xb.c”},{file=”VisualGDBTemplate.c”,fullname=”C:\\Users\\ExtSol\\Desktop\\VisualGDBTemplate\\VisualGDBTemplate.c”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine/_default_types.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine\\_default_types.h”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/_stdint.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\_stdint.h”},{file=”CMSIS/Include/core_cm3.h”,fullname=”C:\\Users\\ExtSol\\Desktop\\VisualGDBTemplate\\CMSIS\\Include\\core_cm3.h”},{file=”CMSIS/Device/ST/STM32F1xx/Include/system_stm32f1xx.h”,fullname=”C:\\Users\\ExtSol\\Desktop\\VisualGDBTemplate\\CMSIS\\Device\\ST\\STM32F1xx\\Include\\system_stm32f1xx.h”},{file=”../../../../../../../newlib/newlib/libc/misc/init.c”,fullname=”/q/gnu/newlib-nano/gcc-arm-none-eabi-6-2017-q2-update/src/newlib-build/arm-eabi/thumb/cortex_m3/newlib/libc/misc/../../../../../../../newlib/newlib/libc/misc/init.c”},{file=”CMSIS/Device/ST/STM32F1xx/Source/system_stm32f1xx.c”,fullname=”C:\\Users\\ExtSol\\Desktop\\VisualGDBTemplate\\CMSIS\\Device\\ST\\STM32F1xx\\Source\\system_stm32f1xx.c”}]
    [ 303 ms] -data-evaluate-expression “&_estack”
    [ 312 ms] ^done,value=”0x20005000″
    [ 312 ms] -var-create – * “*((void **)0x20004ffc)”
    [ 324 ms] ^done,name=”var1″,numchild=”0″,value=”0x20004ffc”,type=”void *”,has_more=”0″
    [ 324 ms] -var-assign “var1″ 0x1e16e18a
    [ 336 ms] ^done,value=”0x1e16e18a”
    [ 336 ms] -data-evaluate-expression “\*\(\(void\ \*\*\)0x20004ffc\)”
    [ 336 ms] -break-insert -f main
    [ 339 ms] ^done,bkpt={number=”2″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08000294″,func=”main”,file=”VisualGDBTemplate.c”,fullname=”C:\\Users\\ExtSol\\Desktop\\VisualGDBTemplate\\VisualGDBTemplate.c”,line=”13″,thread-groups=[“i1″],times=”0″,original-location=”main”}
    [ 1959 ms] -break-delete 1
    [ 1960 ms] ^done
    [ 1960 ms] -gdb-exit
    [ 1960 ms] ^exit
    [ 1960 ms] =thread-group-exited,id=”i1″
    #25318
    This looks like another instance of this issue. Please follow the instructions in another thread to obtain another diagnostic log and we should be able to fix it.
