Sysprogs forums › Forums › VisualGDB › Target path mapping problem
- This topic has 7 replies, 2 voices, and was last updated 1 year ago by
intector.
February 8, 2025 at 09:37 #36379
intector
ParticipantHello,
I’ve got a project and a message that the target mapping is wrong(see attached screenshots). I’ve checked everything, and it looks correct.
For testing, I made a new bare-bone project, which works OK. I copied that project and renamed everything. That copy project compiles without any issues, but when I try to debug, I get the target path error again.
Next, I used the working bare-bone project and tried to make it my starter project. I renamed everything and compiled it without errors. The target path error is back when I start debugging.
The upload limitation prevents me from uploading those two projects, but I’ve created a GitHub repo with them.
GitHub repo: VisualGDB_Target_Path_Error
Thank you
Kai
You must be logged in to view attached files.February 8, 2025 at 09:44 #36382support
KeymasterLooks like something is broken with the symbols. Please make sure you understand which symbols are loaded, which paths are referenced by them, and what paths are expected by gdb.
February 8, 2025 at 15:56 #36383intector
ParticipantHello,
I encountered many boulders on my way, but my project is finally ported to the STM32H7R3L8H6H MCY and compiles without errors. The download to the external memory is also working, and the debugger stops on the breakpoints. The only issue is that I can see any values on any variables. Some variables have random values, and others have standard initial values, but no changes are shown during debugging.
I had this issue earlier and followed the instructions you guys gave me in my earlier post about it, after which it worked. The issue came back for some reason, and I can’t see any values. The program runs and stops on the breakpoints, but that is it pretty much.
I’ve attached the log file for your information.
Thank you
Kai
You must be logged in to view attached files.February 8, 2025 at 16:02 #36385intector
ParticipantHello,
Thank you for the fast answer.
The reason for that behavior was the linker file. I compared the linker file with one generated by STM32CubeMX and found that some spaces in the wrong places caused this problem. I don’t understand how this could cause such issues, but it’s working now. I’ll probably have to learn more about the linked script syntax.
Again, thank you
Kai
February 9, 2025 at 18:52 #36387intector
ParticipantHello Support,
The issue with missing values during debugging is back. I can compile my project without any issues, and the debugger stops on the correct breakpoints, but the variables show only the initial values.
This is from the “VisualGDB Program Output” window:
C:\Users\KaiJensen\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.openocd.st\bin\openocd.exe -c "gdb_port 59761" -c "telnet_port 59759" -f interface/stlink-dap.cfg -f target/stm32h7rx.cfg -c init -c "reset init" -c "echo VisualGDB_OpenOCD_Ready"
Open On-Chip Debugger 0.12.0 (2025-01-22) [https://github.com/STMicroelectronics/OpenOCD]
Licensed under GNU GPL v2
For bug reports, read
Info : auto-selecting first available session transport "dapdirect_swd". To override use 'transport select <transport>'.
stm32h7x_dbgmcu_mmw
Info : STLINK V3J15M7 (API v3) VID:PID 0483:374E
Info : Target voltage: 3.294024
Info : Unable to match requested speed 1800 kHz, using 1000 kHz
Info : clock speed 1000 kHz
Info : stlink_dap_op_connect(connect)
Info : SWD DPIDR 0x6ba02477
Info : [stm32h7x.cpu0] Cortex-M7 r1p2 processor detected
Info : [stm32h7x.cpu0] target has 8 breakpoints, 4 watchpoints
Info : gdb port disabled
Info : starting gdb server for stm32h7x.cpu0 on 59761
Info : Listening on port 59761 for gdb connections
[stm32h7x.cpu0] halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x0800119c msp: 0x20010000
Info : Unable to match requested speed 4000 kHz, using 3300 kHz
Info : Listening on port 59759 for telnet connections
Info : accepting 'gdb' connection on tcp/59761
Info : Device: STM32H7Rx/7Sx
Info : flash size probed value 65535k
Info : STM32H7 flash has a single bank
Info : Bank (0) size is 65535 kb, base address is 0x08000000
Info : New GDB Connection: 1, Target stm32h7x.cpu0, state: halted
Warn : Prefer GDB command "target extended-remote :59761" instead of "target remote :59761"
force hard breakpoints
Error: Failed to read memory at 0x70000c00
Error: Failed to read memory at 0x70000d12
Error: Failed to read memory at 0x70000c1a
Info : dropped 'gdb' connection
shutdown command invokedI also attached the log file.
Thank you
Kai
You must be logged in to view attached files.February 10, 2025 at 09:13 #36394intector
ParticipantHello,
I have a project with an STM32H7R3L8H6H MCU, and I can’t see the values of the variables at breakpoints. This issue occurred earlier, but I applied a patch, and everything worked fine. For some reason, the problem is back. When I start debugging, the variables’ values are always at their initial values.
Here is the “VisualGDB Program Output” window content:
stm32h7x_dbgmcu_mmw
shutdown command invokedI also attached the logfile.
Thank you
Kai
You must be logged in to view attached files.February 10, 2025 at 09:30 #36397support
KeymasterSorry, this doesn’t look like any known issue. Please try following the tutorials from scratch, make sure it works there, and then try comparing the broken project against the working one. If you can point out a specific setting that consistently triggers the problem, we might be able to suggest a workaround.
February 10, 2025 at 12:34 #36398intector
ParticipantHello,
It’s quite possible that this is not a known issue, but what makes me wonder is those error messages:
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTEDError: Failed to read memory at 0x70000c00
Error: Failed to read memory at 0x70000c1aWhy does it have an issue with the libusb_open(), and why is it problematic to read the memory at those addresses? I can read those addresses in the memory listing without any issues.
However, I’ll follow your recommendation and start a new project from scratch as soon as possible. In the meantime, I decided to switch to an STM32H753 MCU. Those “Bootflash” MCUs are fantastic devices, but it’s hard to find good support for them. I might get back to those later.
Thank you
Kai
