Hey,
I am using VisualGDB to build for some STM32 Cortex-M4 processors. My Solution and projects are structured so that i have various library projects and 2 application projects using those libraries.
I now want to add a 3rd processor, an Cortex-M0 and be able to switch to this build with a build configuration. For this my library projects should get another build configuration.
<h2>Can I do this with VisualGDB?!</h2>
Release & Debug configurations both use a XML file (in my case: MCU.xml) and a props file (in my case: MCU.props).
My Libs at the moment build with this:
ASFLAGS: -mfpu=fpv4-sp-d16
Common flags: -mcpu=cortex-m4 -mthumb -mfloat-abi=hard
As i see it, i can create a new build configuration, using another xml file for hardware description. The problem is that the mcu.props also uses this information and can’t be duplicated.
I tried using VisualStudio Project file settings to add CM4 definitions, but this isn’t working.
I fear that just adding another MCU_CM0.xml and referencing to it in the CM0 build configuration will not work either as CM4-Informations are still in the mcu.props file…
