Support for JTAGICE3 / AVR
Sysprogs forums Forums VisualGDB Support for JTAGICE3 / AVR
  • #26542
    David.Horch
    Hi there,
    Is it somehow possible to use the JTAGICE3 AVR Programmer with VisualGDB? The programmer/debugger does not show up in the debug adapter list.
    If not, what about the successor, ATATMEL-ICE-BASIC?
    Usually I am working with ARM controllers but there are currently several projects using AVRs and I don’t want to change my IDE (although Atmel Studio 7.0 is based on Visual Studio).
    Thanks and Best Regards,
    David
    • This topic was modified 6 years, 4 months ago by David.Horch. Reason: Typo
    #26546
    Sorry, our AVR debugging support is based on an open-source tool called AVaRICE, that has somewhat limited support for debug probes. As the AVR devices use undocumented proprietary debugging protocols and are generally much less popular than ARM-based devices, the debugging experience is indeed much less straight-forward.
    Our best advice would be to check the AVaRICE forums/mailing lists regarding support for new debugging probes.
    #26558
    David.Horch
    Hi and thanks for your fast response.
    I’ll keep on using Atmel Studio for that purpose, thanks for the advice.
