Suddenly the ESP32 IDF no longer works in VisualGDB
Sysprogs forums Forums VisualGDB Suddenly the ESP32 IDF no longer works in VisualGDB
  • #36028
    Aloysius_Pendergast
    Everything has worked perfectly for me so far. VisualGDB under Visual Studio 2022 (ESP32 IDF 5.1 and 5.2) suddenly nothing works anymore. I always get the following error message:
    — Detecting CXX compiler ABI info
    — Detecting CXX compiler ABI info – done
    — Check for working CXX compiler: C:/sysgcc/esp32/tools/xtensa-esp-elf/esp-13.2.0_20240530/xtensa-esp-elf/bin/xtensa-esp32-elf-g++.exe – skipped
    — Detecting CXX compile features
    — Detecting CXX compile features – done
    — git rev-parse returned ‘fatal: not a git repository (or any of the parent directories): .git’
    — Could not use ‘git describe’ to determine PROJECT_VER.
    — Building ESP-IDF components for target esp32
    — Checking Python dependencies…
    ERROR: C:\Users\info\.espressif\espidf.constraints.v5.4.txt doesn’t exist. Perhaps you’ve forgotten to run the install scripts. Please check the installation guide for more information.
    — Configuring incomplete, errors occurred!
    CMake Error at C:/sysgcc/esp32/esp-idf/master/tools/cmake/build.cmake:402 (message):
    Some Python dependencies must be installed. Check above message for
    details.
    C:/sysgcc/esp32/esp-idf/master/tools/cmake/build.cmake:539 (__build_check_python)
    C:/sysgcc/esp32/esp-idf/master/tools/cmake/project.cmake:710 (idf_build_process)
    CMakeLists.txt:6 (project)
    Even a new installation did not help.
    #36029
    Please refer to this page for a detailed explanation of ESP-IDF integration and troubleshooting tips.
