Sysprogs forums › Forums › VisualGDB › STM32G4 OpenOCD bugged?
- This topic has 4 replies, 2 voices, and was last updated 6 years, 1 month ago by
tm123.
March 5, 2020 at 19:09 #27572
tm123
ParticipantHi, I updated VisualGDB from an older version and all of a sudden OpenOCD refuses to connect to my STM32G4.
Open On-Chip Debugger 0.10.0 (2020-02-28) [https://github.com/sysprogs/openocd]
Licensed under GNU GPL v2
For bug reports, read
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
target/stm32g4x.cfg:59: Error: invalid command name "adapter_khz"
in procedure 'script'
at file "embedded:startup.tcl", line 26
at file "target/stm32g4x.cfg", line 59March 5, 2020 at 19:22 #27573support
No problem, looks like the upstream OpenOCD has renamed some JTAG-related commands and some of the scripts shipped with our OpenOCD build were not updated.
We have fixed the issue. Please try reinstalling the OpenOCD release via Tools->VisualGDB->Manage VisualGDB Packages.
March 5, 2020 at 19:31 #27574tm123
ParticipantThat made it further however there’s still more issues, apparently it can’t see it as an L4 or WB.
Info : clock speed 500 kHz
Info : STLINK v3 JTAG v6 API v3 M2 VID 0x0483 PID 0x374E
Info : using stlink api v3
Info : Target voltage: 3.294400
Info : Unable to match requested speed 500 kHz, using 200 kHz
Info : Stlink adapter speed set to 200 kHz
Info : stm32l4x.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : Listening on port 56724 for gdb connections
xPSR: 0x01000000 pc: 0x08003310 msp: 0x20005800
VisualGDB_OpenOCD_Ready
Info : Listening on port 56723 for telnet connections
Info : accepting 'gdb' connection on tcp/56724
Warn : Cannot identify target as an STM32 L4 or WB family device.
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejectedMarch 5, 2020 at 23:18 #27575support
KeymasterNo problem, we have investigated this and released another update. Please update your OpenOCD package via the VisualGDB Package Manager.
March 6, 2020 at 15:50 #27577tm123
ParticipantAwesome, it is working again. Great work!
