Sysprogs forums › Forums › VisualGDB › STM32F030F4 debug problem
- This topic has 2 replies, 2 voices, and was last updated 8 years, 12 months ago by
kaseat.
March 19, 2017 at 19:30 #10712
kaseat
I’ve tried to flash Cortex M0 STM32F030F4 MCU with VisualGDB plugin but faced with “Failed to verify the programmed image” problem (see GDBServer log below), while CoIDE’s debugger works fine with the same MCU. Cortex M3 STM32F103C8 MCU debuging with VisualGDB aslo works fine.
I’ve examined STM32F030F4 and STM32F103C8 GDBServer logs and found this values a little bit suspicious: xPSR: 0xc1000000 pc: 0xfffffffe msp: 0xfffffffc (STM32F030F4) as opposite: xPSR: 0x01000000 pc: 0x08000200 msp: 0x20005000 (STM32F103C8).
Do you have any ideas how to workaround this issue?
Thanks.
STM32F030F4 GDBServer log:
Open On-Chip Debugger 0.9.0 (2016-10-14) [https://github.com/sysprogs/openocd]
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 1000 kHz
adapter_nsrst_delay: 100
none separate
Info : Unable to match requested speed 1000 kHz, using 950 kHz
Info : clock speed 950 kHz
Info : STLINK v2 JTAG v17 API v2 SWIM v4 VID 0x0483 PID 0x3748
Info : using stlink api v2
Info : Target voltage: 3.295187
Info : stm32f0x.cpu: hardware has 4 breakpoints, 2 watchpoints
stm32f0x.cpu: target state: halted
in procedure ‘reset’
in procedure ‘ocd_bouncer’
in procedure ‘ocd_process_reset’
in procedure ‘ocd_process_reset_inner’ called at file “embedded:startup.tcl”, line 248
in procedure ‘stm32f0x.cpu’ called at file “embedded:startup.tcl”, line 370
in procedure ‘ocd_bouncer’Error: jtag status contains invalid mode value – communication failure
Polling target stm32f0x.cpu failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
VisualGDB_OpenOCD_Ready
Info : Previous state query failed, trying to reconnect
Info : accepting ‘gdb’ connection on tcp/58463
Info : device id = 0x10006444
Info : flash size = 16kbytes
Error: address + size wrapped(0xfffffffe, 0x00000004)
Examination failed, GDB will be halted. Polling again in 100msInfo : Previous state query failed, trying to reconnect
xPSR: 0xc1000000 pc: 0xfffffffe msp: 0xfffffffcMarch 19, 2017 at 22:05 #10714support
This could be an indication of a wiring problem, so errors can occur intermittently and it may appear that one IDE works, while a different IDE with slightly different timings does not. Please double-check your board connections.
Another reason for this could be that your firmware is disabling the JTAG unit. Please try modifying the OpenOCD scripts as shown in this tutorial to enable the “connect under reset” mode.
March 20, 2017 at 08:17 #10717kaseat
ParticipantThanks for your reply!
This seems to be a wiring problem since enabling the “connect under reset” mode did not help. I’ll try another dev board then. -
