Sysprogs forums › Forums › VisualGDB › STM32CubeMX project importer failed with exception
- This topic has 3 replies, 2 voices, and was last updated 8 years, 7 months ago by
August 24, 2017 at 06:14 #12164
jeneena
ParticipantI’m testing new STM32CubeMX project importer.
I selected .gpdsc file, then click “Finish”, but import failed with exception (System.ArgumentException – illegal characters in path).
Did i do anything wrong?
*Settings:
-All default options.
-Checked “Move Visual Studio project to the imported project directory”
-No blank or special characters in project path.
VisualGDB version: 5.3.6.1730
—————— System.ArgumentException ——————
System.ArgumentException: 경로에 잘못된 문자가 있습니다. –> “illegal characters in path”
위치: System.Security.Permissions.FileIOPermission.EmulateFileIOPermissionChecks(String fullPath)
위치: System.Security.Permissions.FileIOPermission.QuickDemand(FileIOPermissionAccess access, String fullPath, Boolean checkForDuplicates, Boolean needFullPath)
위치: yx1.h(String c, String a, Boolean b)
위치: nt.b.b(ImportedFile a)
위치: System.Linq.Enumerable.WhereSelectListIterator`2.MoveNext()
위치: System.Linq.Buffer1..ctor(IEnumerable1 source)
위치: System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source)
위치: nt.a(VirtualDirectory b, String a)
위치: nt.b.c(VirtualDirectory a)
위치: k41.d(String b, ImportedExternalProject a)
위치: VisualGDB.Wizard.Embedded.EmbeddedProjectWizardImpl.a(EmbeddedWizardState b, IProjectEditContext d, String e, String c, xl a)
위치: VisualGDB.Wizard.Embedded.EmbeddedProjectWizardImpl.DoRunWizardOrThrowException(xl a, String b, String c)
위치: oj1`1.Execute(Object d, Int32 e, Object[]& c, Object[]& b, wizardResult& a)-
This topic was modified 8 years, 7 months ago by
jeneena.
jeneena.
You must be logged in to view attached files.August 24, 2017 at 18:34 #12181support
Please try using this build: http://sysprogs.com/files/tmp/VisualGDB-5.3.7.1746.msi
It will display the path that caused the exception.
August 25, 2017 at 05:01 #12182jeneena
ParticipantThank you.
I tested with build as you mentioned, it failed with exception like this:—————— System.Reflection.TargetInvocationException ——————
System.Reflection.TargetInvocationException: GetRelativePath(‘C:\Users\bryce\Desktop\test\stm32cubemx_test’, ‘C:\Users\bryce\Desktop\test\stm32cubemx_test\Middlewares\Third_Party\LwIP\src\include\*‘) failed –
illegal characters in path. —> System.ArgumentException: illegal characters in path.
it looks like the path contains wildcard(‘*’).
Is this the cause of the problem?
VisualGDB version: 5.3.7.1746
System.Reflection.TargetInvocationException: GetRelativePath(‘C:\Users\bryce\Desktop\test\stm32cubemx_test’, ‘C:\Users\bryce\Desktop\test\stm32cubemx_test\Middlewares\Third_Party\LwIP\src\include\*’) failed – 경로에 잘못된 문자가 있습니다. —> System.ArgumentException: 경로에 잘못된 문자가 있습니다.
위치: fg1.g(String a, String c, Boolean b)
— 내부 예외 스택 추적의 끝 —
위치: zl.a.b(ImportedFile a)
위치: zl.b(VirtualDirectory b, String a)
위치: zl.a.c(VirtualDirectory a)
위치: e11.c(String b, ImportedExternalProject a)
위치: VisualGDB.Wizard.Embedded.EmbeddedProjectWizardImpl.g(EmbeddedWizardState b, IProjectEditContext c, String a, String e, s d)
위치: VisualGDB.Wizard.Embedded.EmbeddedProjectWizardImpl.DoRunWizardOrThrowException(s b, String a, String c)
위치: lm`1.Execute(Object d, Int32 a, Object[]& e, Object[]& c, wizardResult& b)
—————— Inner exception ——————
위치: fg1.g(String a, String c, Boolean b)August 27, 2017 at 04:36 #12187support
Thanks, we have fixed this in the following build: http://sysprogs.com/files/tmp/VisualGDB-5.3.7.1748.msi
