Sysprogs forums › Forums › VisualGDB › STM32 Dual Core startup / debug
- This topic has 12 replies, 2 voices, and was last updated 5 years, 9 months ago by
June 24, 2020 at 00:31 #28507
dp
ParticipantI am trying to setup a new project using the Nucleo-H745ZI. I have my own custom board built but I am trying to test using a Nucleo-H745ZI first.
I have followed the tutorial at https://visualgdb.com/tutorials/arm/stm32/multicore/
I have two projects M7 and M4 both all defaults except M7 toggles LED GPIOB Pin_0 (Nucleo LED 1) and M4 toggles GPIOE Pin_1 (Nucleo LED 2). The projects are just the default template toggle LED project as outlined in the tutorial.
I start the m7 core and debug. The LED 1 blinks as expected.
The tutorial says to put a break point and start the other project So I do this hit a breakpoint, and try to start the M4 core I get the error message of “Error: open failed (no matching adapter found)”
with the following GDB stub log:
C:\Users\D\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.openocd\bin\openocd.exe -c “gdb_port 59335” -c “telnet_port 59334” -f interface/stlink.cfg -f target/stm32h7x_dual_core.cfg -c init -c “reset init” -c “echo VisualGDB_OpenOCD_Ready”
Open On-Chip Debugger 0.10.0 (2020-03-10) [https://github.com/sysprogs/openocd]
Licensed under GNU GPL v2
For bug reports, read
Info : clock speed 4000 kHz
Error: libusb_open() failed with LIBUSB_ERROR_ACCESS
Error: open failed (no matching adapter found)To me it looks like libusb is not allowing another connection or I must be missing a setting somewhere but so far I cannot find it.
Also if I stop the M7 core and start the M4 core the debugger start but program never leaves the reset handler.
I have gone through the tutorial 3 times now being careful to check every selection but some of the screens have changed since the tutorial was published. For example there is no longer an option to put project and solution in the same directory though I believe this is the default behavior now. I also tried putting both projects into the same directory without success.
I am not super concerned about debugging simultaneously but would really like to start the second core and so far I cannot see how to do this. On my custom board I will be using a Segger JLink debugger.
I have tried the examples from STM32H7 Cube for dual core and it seems to work fine.
DP
June 24, 2020 at 00:45 #28508support
This might be caused by the way STM32H7 devices initialize the secondary core. We have a separate tutorial explaining it.
Please also make sure you are using VisualGDB 5.5 Preview 7 and not v5.4.
If it doesn’t help, please let us know and we will look further into this.
June 24, 2020 at 02:59 #28509dp
ParticipantI installed version 5.5 preview 7 and now debugging starts as you would expect but still the M4 core will not start.
Following the steps in your tutorial The M7 core starts fine but M4 does not start and stays huge in the reset handler.
I suspect I am missing some essential code needed to start the M4 code.
June 24, 2020 at 20:48 #28518dp
ParticipantI also tried importing the keil project included in the Cube H7 package.
While it works in keil. After importing I can start M7 core but M4 core never leaves reset while debugging with VisualGDB.
D
June 25, 2020 at 00:51 #28520support
KeymasterNo problem, we can help you get this to work. Please try modifying the code to control one of the LEDs from the M4 core. Then check if the core gets started when you are not debugging it (i.e. program the FLASH both memory banks and power cycle the device).
If the second core never starts outside the debugger as well, please try comparing the startup code on the first core with some example that manages to start the second core successfully. Most likely, the example is missing some code for actually starting the M4 core.
June 25, 2020 at 04:31 #28521dp
ParticipantThe second core never starts with or without debugger.
As mentioned I imported example that works in keil, After setting up the projects the M7 core will start but the M4 core will never start in visualGDB.
Note when importing the project and selecting the MCU there is no separate option for STM32H745zi_M4 like there is when you start a new project but I was able to hand configure the parameters for the core but something is still wrong.
Lastly I went a did a very simple example for core and could make it work in other products but could not make it work with visual GDB.
June 26, 2020 at 18:32 #28534support
KeymasterSorry about that. We have double-checked the STM32H745ZI support with the latest OpenOCD and it did work as expected. Please make sure you install the latest VisualGDB 5.5 Preview 7 and update the OpenOCD package and the STM32 BSP via Tools->VisualGDB->Manage VisualGDB Packages.
Please also try erasing the entire FLASH memory of the device via the STM32 ST-Link Utility.
If it still doesn’t help, please share the screenshots of the GUI that is missing the M4 option you mentioned, and we will help you understand what is going on.
June 26, 2020 at 18:35 #28535dp
ParticipantWould it be possible for you to post the projects files from the tutorial at? https://visualgdb.com/tutorials/arm/stm32/multicore/
With these I could test it and see if I can find the problem.
Maybe your projects that worked for you will work for me. Otherwise I have tried everything I can think of to bring up the second core.
DPJune 26, 2020 at 18:59 #28536support
KeymasterNo problem, you can find them here: https://github.com/sysprogs/tutorials/tree/master/visualgdb/ARM/stm32/STM32MultiCoreDemo
June 29, 2020 at 14:49 #28605dp
ParticipantThanks for your help on this. I am now certain this problem is related to the Nucleo-STM32H745. I tested it today on my custom boards using that has a STM32H745ZI with a segger J-link and works just as your tutorial says. So I think all is good with the software but might be a problem with the Dual Core Nucleo board.
June 29, 2020 at 17:45 #28606support
KeymasterThanks for confirming this. There might be indeed minor differences between STM32H745 and STM32H747 that could be affecting this. E.g. the M4 core might start suspended and may need to be explicitly started by the M7 core.
If you would like to narrow it down, please consider cloning some of the multi-core STM32CubeMX samples for the Nucleo board, rather than using the default LEDBlink example. These samples come directly from ST and should account for differences between the boards.
June 29, 2020 at 18:29 #28608dp
ParticipantI don’t know what the problem is with the nucleo but I tried two of them with the same result. But using the same processor STM32H745ZI in my board worked fine.
I suspect it might be related the power source of the processor Nucleo STM32H745 are configured for PWR_DIRECT_SMPS_SUPPLY
But I do not need any more help at the moment I am up and building on my board and that is all that matters but wanted to let you know if you run into again.
June 29, 2020 at 18:30 #28610support
KeymasterNo problem and thanks for letting us know. If you encounter any further issues, feel free to start another thread and we will be happy to help.
