Sysprogs forums › Forums › Other tools & products › srvman compilation error using VS2008
- This topic has 0 replies, 1 voice, and was last updated 15 years, 9 months ago by
ah6511.
May 31, 2010 at 20:48 #198
ah6511
ParticipantI got following compilation error, any ideas?
1>
Build started: Project: srvman, Configuration: Debug Win32
1>Compiling…
1>cmdline.cpp
1>d:samplessysprogssrvmancmdline.cpp(353) : error C2664: ‘BazisLib::FilePath::FilePath(const BazisLib::TempString &)’ : cannot convert parameter 1 from ‘const BazisLib::iwstring’ to ‘const BazisLib::TempString &’
1> Reason: cannot convert from ‘const BazisLib::iwstring’ to ‘const BazisLib::TempString’
1> No user-defined-conversion operator available that can perform this conversion, or the operator cannot be called
1>d:samplessysprogssrvmancmdline.cpp(355) : error C2039: ‘c_str’ : is not a member of ‘BazisLib::_TempStringImplT<_chartype>‘
1> with
1> [
1> _CharType=TCHAR
1> ]
1>d:samplessysprogssrvmancmdline.cpp(371) : error C2039: ‘append’ : is not a member of ‘BazisLib::FilePath’
1> d:samplessysprogsbazislibbzscmnfile.h(165) : see declaration of ‘BazisLib::FilePath’
1>d:samplessysprogssrvmancmdline.cpp(396) : error C2440: ‘initializing’ : cannot convert from ‘BazisLib::DynamicStringA’ to ‘std::basic_string<_Elem,_Traits,_Ax>‘
1> with
1> [
1> _Elem=char,
1> _Traits=std::char_traits,
1> _Ax=std::allocator
1> ]
1> No constructor could take the source type, or constructor overload resolution was ambiguous
1>MainDlg.cpp
1>d:samplessysprogssrvmanmaindlg.cpp(497) : error C2039: ‘AccessDeined’ : is not a member of ‘BazisLib’
1>d:samplessysprogssrvmanmaindlg.cpp(497) : error C2065: ‘AccessDeined’ : undeclared identifier
1>PropertiesDlg.cpp
1>d:samplessysprogssrvmanpropertiesdlg.cpp(424) : error C2039: ‘c_str’ : is not a member of ‘BazisLib::_TempStringImplT<_chartype>‘
1> with
1> [
1> _CharType=TCHAR
1> ]
1>d:samplessysprogssrvmanpropertiesdlg.cpp(544) : error C2039: ‘c_str’ : is not a member of ‘BazisLib::_TempStringImplT<_chartype>‘
1> with
1> [
1> _CharType=TCHAR
1> ]
1>Generating Code…
1>Build log was saved at “file://d:SamplesSysProgsSrvManDebugBuildLog.htm”
1>srvman – 8 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ========== -
