source files paths cached somewhere?
Sysprogs forums Forums VisualGDB source files paths cached somewhere?
  • #10891
    thedixon
    I went into the project file, and manually changed some paths. e.g.
    c:\users\dnikitin\dev\project\name.cpp
    to
    c:\users\dnikitin\dev\project\src\name.cpp
    Now when I load the project and look into the intellisense diagnostic console, I see complaints that
    Can’t open file c:\users\dnikitin\dev\project\name.cpp
    Funnily enough, intellisense seems to work after that. Where does it pull those old file paths from, I can’t find them mentioned anywhere in the project directory?
    #10896
    The Clang IntelliSense caches the old file paths in the global file table in order to speed up the up-to-date check operations. The message can be safely ignored, but you can also simply remove the CodeDB directory to discard the IntelliSense cache.
