Source file path mapping
Sysprogs forums Forums VisualGDB Source file path mapping
  • #30914
    noethlichs.t
    When I want to set a breakpoint during remote debugging, VisualGDB takes the target folder from the file synchronization settings. The binary I am debugging, however, has been build through other means. The GDB raw log looks like this:
    -break-insert -f /home/visualgdb/c/Source/hello-world/main.cpp:148
    &"No source file named /home/visualgdb/c/Source/hello-world/main.cpp:148.\n"
    I need to map the paths to:
    /home/default/build/Source/hello-world/main.cpp:148
    In the other direction, the path mapping from the VisualGDB settings works. If a breakpoint that has been set manually I get redirected to the correct source file.
    #30915
    Please refer to the following page for more information on path mapping: https://visualgdb.com/documentation/pathmapping/
    #30917
    noethlichs.t
    I have read this page. It does not help me.
    When setting a breakpoint in a file, I need VisualGDB to use a different path than the $(SourceDir). Because when compiling, the file was not inside $(SourceDir).
    • This reply was modified 4 years, 9 months ago by noethlichs.t.
    #30936
    A custom source path mapping should take care of that. If it doesn’t work, please attach a screenshot of your path mapping settings, the full path of the file on Windows where you are trying to set a breakpoint, and a gdb log showing the command that VisualGDB used to set the breakpoint.
