Solution to: "The specified service has been marked for del"
Sysprogs forums Forums WinCDEmu Solution to: "The specified service has been marked for del"
  • #322
    Natasha
    When you install/unistall driver of WinCDEmu Portable in the same session working perfect. For example simpy open software/install driver and before close software/uninstall driver.
    But if you need to install again in the same session the pcs need to reboot. The error message is:
    The specified service has been marked for deletion
    I have test on 4 Pcs and the problem is the same, so i find a simple solution:
    Start — cmd — driverquery
    With this comman the driver list must be “refresh” and we can fine install driver again without reboot.
    Hope someone needs
    #1885
    Super, thank you! πŸ˜€
    #1886
    It works, hope bazis insert this cmd command in the new portable version, is easy but funcional.
    When the new version coming out? How knew…
