SmarTTY key bindings
Sysprogs forums Forums Other tools & products SmarTTY key bindings
  • #25025
    npquintos
    This is a very good tool indeed but there is just this minor thing (which is a HUGE deal for vim/tmux users out there): Backspace and Ctrl-h are emitting the same key codes: ^?
    Backspace should be ^? and Ctrl-h should be ^H. Otherwise, you could not jump panes/splits to the left of the active pane/split. More generally, it would be very nice to be able to make a custom mapping for these problematic keys (Backspace, Del, Ctrl-h or any key combination with Ctrl). I could see that you already allowed this with the Alt key which is great.  Thanks!
    #26042
    clediomp
    Smartty is the ultimate tool for multiple server administration… but there is an issue that is very relevant.
    I have a problem with Smartty when editing texts with nano or vi… when i use backspace the text goes crazy…maybe is the same issue..
    Im running it on Windows 10.
