SmarTTY and saving coinnections
Sysprogs forums Forums Other tools & products SmarTTY and saving coinnections
  • #660
    when connecting to a linux box which uses AD authentication it is not possible to save the connection, because of in filefoldername
    User:
    DOMAINUsername
    Connection will be save as DOMAINUsername@host
    It fails because of the backslash
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:UsersUserAppDataRoamingSmarTTYSavedConnectionsDOMAINusername@host.sshconnection'.
    at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
    at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options)
    at VisualTTY.SSHConnectionSettings.Save()
    at cf.b(SSHConnectionSettings A_0)
    at f.a(SSHConnectionSettings A_0)
    at f.d(Object A_0, EventArgs A_1)
    at System.Windows.Forms.Form.OnShown(EventArgs e)
    at System.Windows.Forms.Form.CallShownEvent()
    at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
    at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
    at System.Threading.ExecutionContext.runTryCode(Object userData)
    at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
    at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
    at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
    at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
    at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
    is there a way around?
    Thanks in advance.
    SF2013
    #2683
    Fixed in SmarTTY 1.1 (http://smartty.sysprogs.com/download/)
    #2684
    thanks for the fix, works perfect now!
    SF2013
