Setup Bug: Selecting WDK in the DDK entry …
Sysprogs forums Forums VisualDDK/VirtualKD discussion Setup Bug: Selecting WDK in the DDK entry …
  • #249
    Ephraim
    Hey,
    I think the setup finalize wizard has a bug. When you select a WDK Path via the DDK Browse button, it will prompt you with an error. Fair enough.
    But if you then select the same path via WDK browse button, neither next nor finish will be activated, so you have no chance to finish the setup.
    After restarting the setup and directly using the WDK browse button, all works fine.
    Ciao Ephraim
    #1587
    arofree
    “7600.16385.1”
    rename
    “7600”
