Setting to not activate GDB Session Window
Sysprogs forums Forums VisualGDB Setting to not activate GDB Session Window
  • #21706
    Jensa
    I got the tip to use the GUI setting “Don’t Activate GDB Session Window” since I didn’t know it existed before and requested the exact feature.
    Now that I’ve tried it though I’ve got some weird issues with it. When I have it enabled and I try to start a debug session it changes to the debug layout etc but then nothing really happens. If I then switch manuully to the GDB Session tab everything continues as normal. It seems it doesn’t start deployment etc unless you have the GDB Session tab active. When you do you can switch back to whatever tab you want and it works fine.
    Regards
    Jens Nilsson
    #21709
    This looks like a problem that was recently fixed. Please try the latest daily build: http://sysprogs.com/files/tmp/VisualGDB-5.4.4.2400.msi.
