Sysprogs forums › Forums › VisualGDB › Set next statement and run to cursor problem
- This topic has 4 replies, 2 voices, and was last updated 9 years, 1 month ago by
sidprice.
February 9, 2017 at 20:07 #10352
sidprice
ParticipantI am working with an ARM embedded project and I think there is a problem with set next statement. I have been running a small segment of my code so that I can measure a pulse output, checking my timing calculations. To do this I use “Set next statement” followed by “Run to cursor”. What appears to happen is that “Set next statement” does not set the target MCU to the correct place until I use “Run to cursor”, I have to use “Run to cursor” a second time to get the target to actually run to the selected line.
After the “Set next line” the PC appears to be correct, however the first “Run to cursor” does not run to that line and the PC remains the same.
Sid
February 11, 2017 at 00:04 #10367support
This is expected if you are debugging optimized code (the mapping between source lines and the actual instructions is very inaccurate then).
If you can reproduce this in the unoptimized code, please provide us more details so that we could look into this:
- A snippet from your source file with the line numbers
- A snippet from the gdb log (or the ‘all gdb interaction’ mode of the GDB Session window) showing the commands and gdb responses that are executed in response to using the “Set next statement” command. This should explain what is going on.
February 13, 2017 at 18:22 #10390sidprice
ParticipantCode snippet:
144 int sl_IfWrite( Fd_t fd, unsigned char *pBuffx, int len )
145 {
146 _CC3100_ChipSelect(); // Assert the chip select
147 //
148 // Write the data as words
149 //
150 u_int16_t * pOutput = (u_int16_t * )pBuffx;
151 for ( int iLoop = 0; iLoop < len ; iLoop += 2, pOutput++ )
152 {
153 spi_xfer( SPI1, _CC3100_ByteSwap( *pOutput ) );
154 }
155 _CC3100_ChipDeselect(); // Negate the chip select
156 return ( len ) ;
157 }With the MCU stopped at a breakpoint on line #157 I “Set Next Statment” on line #146:
info line “C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/cc3100.c”:146
&”info line \”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/cc3100.c\”:146\n”
~”Line 146 of \”platforms/WifiF4/cc3100.c\” starts at address 0x80023cc <sl_IfWrite+4> and ends at 0x80023d0 <sl_IfWrite+8>.\n”
^done
-var-create – * $pc
^done,name=”var11″,numchild=”0″,value=”0x80023fe <sl_IfWrite+54>”,type=”void (*)()”,has_more=”0″
-var-assign var11 0x80023cc
^done,value=”0x80023cc <sl_IfWrite+4>”
-var-delete var11
^done,ndeleted=”1″
-stack-list-frames –thread 1
^done,stack=[frame={level=”0″,addr=”0x080023cc”,func=”sl_IfWrite”,file=”platforms/WifiF4/cc3100.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\cc3100.c”,line=”146″},frame={level=”1″,addr=”0x080034d6″,func=”_SlDrvRxHdrRead”,file=”simplelink/source/driver.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\source\\driver.c”,line=”1583″},frame={level=”2″,addr=”0x080034d6″,func=”_SlDrvMsgRead”,file=”simplelink/source/driver.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\source\\driver.c”,line=”964″},frame={level=”3″,addr=”0x08003a6c”,func=”_SlDrvMsgReadSpawnCtx”,file=”simplelink/source/driver.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\source\\driver.c”,line=”1424″},frame={level=”4″,addr=”0x0800409e”,func=”_SlNonOsMainLoopTask”,file=”simplelink/source/nonos.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\source\\nonos.c”,line=”189″},frame={level=”5″,addr=”0x0800413e”,func=”_SlNonOsSemGet”,file=”simplelink/source/nonos.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\source\\nonos.c”,line=”111″},frame={level=”6″,addr=”0x08003c54″,func=”_SlDrvSyncObjWaitTimeout”,file=”simplelink/source/driver.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\source\\driver.c”,line=”2075″},frame={level=”7″,addr=”0x080029c4″,func=”sl_Start”,file=”simplelink/source/device.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\source\\device.c”,line=”146″},frame={level=”8″,addr=”0x080024ea”,func=”_CC3100_Setup”,file=”platforms/WifiF4/cc3100.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\cc3100.c”,line=”296″},frame={level=”9″,addr=”0x080026c8″,func=”cc3100_init”,file=”platforms/WifiF4/cc3100.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\cc3100.c”,line=”488″},frame={level=”10″,addr=”0x080028a0″,func=”platform_init”,file=”platforms/WifiF4/platform.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\platform.c”,line=”113″},frame={level=”11″,addr=”0x08001538″,func=”main”,file=”main.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\main.c”,line=”54″}]
-stack-list-arguments –thread 1 0
^done,stack-args=[frame={level=”0″,args=[name=”fd”,name=”pBuffx”,name=”len”]},frame={level=”1″,args=[name=”pAlignSize”,name=”pBuf”]},frame={level=”2″,args=[]},frame={level=”3″,args=[name=”pValue”]},frame={level=”4″,args=[]},frame={level=”5″,args=[name=”pSyncObj”,name=”WaitValue”,name=”SetValue”,name=”Timeout”]},frame={level=”6″,args=[name=”pSyncObj”,name=”timeoutVal”,name=”apiIdx”]},frame={level=”7″,args=[name=”pIfHdl”,name=”pDevName”,name=”pInitCallBack”]},frame={level=”8″,args=[]},frame={level=”9″,args=[]},frame={level=”10″,args=[]},frame={level=”11″,args=[name=”argc”,name=”argv”]}]
-var-create –frame 0 –thread 1 – * “while”
^error,msg=”-var-create: unable to create variable object”If I then use the “Continue command” the MCU stays on line #146:
-var-create –frame 0 –thread 1 – * “select”
-var-create –frame 0 –thread 1 – * “sl_Select”
-exec-continue
^running
*running,thread-id=”all”
=breakpoint-modified,bkpt={number=”2″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x080023cc”,func=”sl_IfWrite”,file=”platforms/WifiF4/cc3100.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\cc3100.c”,line=”146″,thread-groups=[“i1″],times=”2″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/cc3100.c:146″}
~”\n”
~”Breakpoint 2, sl_IfWrite (fd=0x0, pBuffx=0x7856 \”W\322\260\365\\001OT\320H\362\\020\\023\\230BP\320\”, pBuffx@entry=0x80169a8 <g_H2NCnysPattern+4> \”e\207xV\\377\356\335\273!C4\\022/\234\\030\\004\\064\234\\f\\004\\062\204\\b\\004m\214\\004\\004\265\214\\b\\004\264\214\\004\\004\\060x%lx: 0x%lx <- does not match preamble (0x%X)\\n\”, len=1024, len@entry=4) at platforms/WifiF4/cc3100.c:146\n”
~”146\t\t_CC3100_ChipSelect();\t\t// Assert the chip select\n”
*stopped,reason=”breakpoint-hit”,disp=”keep”,bkptno=”2″,frame={addr=”0x080023cc”,func=”sl_IfWrite”,args=[{name=”fd”,value=”0x0″},{name=”pBuffx”,value=”0x7856 \”W\322\260\365\\001OT\320H\362\\020\\023\\230BP\320\””},{name=”pBuffx@entry”,value=”0x80169a8 <g_H2NCnysPattern+4> \”e\207xV\\377\356\335\273!C4\\022/\234\\030\\004\\064\234\\f\\004\\062\204\\b\\004m\214\\004\\004\265\214\\b\\004\264\214\\004\\004\\060x%lx: 0x%lx <- does not match preamble (0x%X)\\n\””},{name=”len”,value=”1024″},{name=”len@entry”,value=”4″}],file=”platforms/WifiF4/cc3100.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\cc3100.c”,line=”146″},thread-id=”1″,stopped-threads=”all”
-break-after 2 0
^done
^done,stack-args=[frame={level=”0″,args=[name=”fd”,name=”pBuffx”,name=”len”]},frame={level=”1″,args=[name=”pAlignSize”,name=”pBuf”]},frame={level=”2″,args=[]},frame={level=”3″,args=[name=”pValue”]},frame={level=”4″,args=[]},frame={level=”5″,args=[name=”pSyncObj”,name=”WaitValue”,name=”SetValue”,name=”Timeout”]},frame={level=”6″,args=[name=”pSyncObj”,name=”timeoutVal”,name=”apiIdx”]},frame={level=”7″,args=[name=”pIfHdl”,name=”pDevName”,name=”pInitCallBack”]},frame={level=”8″,args=[]},frame={level=”9″,args=[]},frame={level=”10″,args=[]},frame={level=”11″,args=[name=”argc”,name=”argv”]}]NOTE: There is a breakpoint on line #146, if I remove the breakpoint, set the next line to #146, and continue it works correctly,
Sid
February 13, 2017 at 18:35 #10391support
Thanks for clarifying this. It is actually a known behavior of gdb. When jumping to a line with a breakpoint, the breakpoint will get triggered after resuming the program as if the line got reached naturally.
It should not interfere with anything else; simply press F5 or F10 again to continue debugging.
February 13, 2017 at 18:54 #10395sidprice
ParticipantThanks, Sid
