SAM4S + Atmel ICE: Debugger not working
Sysprogs forums Forums VisualGDB SAM4S + Atmel ICE: Debugger not working
  • #32815
    Physikant
    our company is using VisualGDB to develop embedded Software for Microchip SAM devices. We are using the Atmel ICE ISP for this. VisualGDB  is working flawless with the SAME70, however debugging is almost impossible on SAM4S. It’s not a hardware issue; everything is working fine in Atmel/Microchip Studio.
    Here is what usually happens:
    • the chip erase takes unusually long, but works in the end
    • after that, an exception is triggered at the reset handler line “_libc_init_array()”, so before the main(). The exception is: “Received a SIGTRAP: Trace/breakpoint trap”. The execution can not be continued.
    Sometimes, a hard erase is needed after this. Sometimes, the execution progresses and it runs to the first breakpoint, but never hits another one after this (although the code is working in Atmel/Microchip Studio).
    OpenOCD-Log:
    xPSR: 0x01000000 pc: 0x0080004c msp: 0x20000800
    Info : Erasing FLASH: 0x00400000-0x00482000...
    Info : sam4 does not auto-erase while programming (Erasing relevant sectors)
    Info : sam4 First: 0x00000000 Last: 0x00000040
    Info : Erasing sector: 0x00000000
    Info : Erasing sector: 0x00000001
    Info : Erasing sector: 0x00000002
    Info : Erasing sector: 0x00000003
    Info : Erasing sector: 0x00000004
    Info : Erasing sector: 0x00000005
    Info : Erasing sector: 0x00000006
    Info : Erasing sector: 0x00000007
    Info : Erasing sector: 0x00000008
    Info : Erasing sector: 0x00000009
    Info : Erasing sector: 0x0000000a
    Info : Erasing sector: 0x0000000b
    Info : Erasing sector: 0x0000000c
    Info : Erasing sector: 0x0000000d
    Info : Erasing sector: 0x0000000e
    Info : Erasing sector: 0x0000000f
    Info : Erasing sector: 0x00000010
    Info : Erasing sector: 0x00000011
    Info : Erasing sector: 0x00000012
    Info : Erasing sector: 0x00000013
    Info : Erasing sector: 0x00000014
    Info : Erasing sector: 0x00000015
    Info : Erasing sector: 0x00000016
    Info : Erasing sector: 0x00000017
    Info : Erasing sector: 0x00000018
    Info : Erasing sector: 0x00000019
    Info : Erasing sector: 0x0000001a
    Info : Erasing sector: 0x0000001b
    Info : Erasing sector: 0x0000001c
    Info : Erasing sector: 0x0000001d
    Info : Erasing sector: 0x0000001e
    Info : Erasing sector: 0x0000001f
    Info : Erasing sector: 0x00000020
    Info : Erasing sector: 0x00000021
    Info : Erasing sector: 0x00000022
    Info : Erasing sector: 0x00000023
    Info : Erasing sector: 0x00000024
    Info : Erasing sector: 0x00000025
    Info : Erasing sector: 0x00000026
    Info : Erasing sector: 0x00000027
    Info : Erasing sector: 0x00000028
    Info : Erasing sector: 0x00000029
    Info : Erasing sector: 0x0000002a
    Info : Erasing sector: 0x0000002b
    Info : Erasing sector: 0x0000002c
    Info : Erasing sector: 0x0000002d
    Info : Erasing sector: 0x0000002e
    Info : Erasing sector: 0x0000002f
    Info : Erasing sector: 0x00000030
    Info : Erasing sector: 0x00000031
    Info : Erasing sector: 0x00000032
    Info : Erasing sector: 0x00000033
    Info : Erasing sector: 0x00000034
    Info : Erasing sector: 0x00000035
    Info : Erasing sector: 0x00000036
    Info : Erasing sector: 0x00000037
    Info : Erasing sector: 0x00000038
    Info : Erasing sector: 0x00000039
    Info : Erasing sector: 0x0000003a
    Info : Erasing sector: 0x0000003b
    Info : Erasing sector: 0x0000003c
    Info : Erasing sector: 0x0000003d
    Info : Erasing sector: 0x0000003e
    Info : Erasing sector: 0x0000003f
    Info : Erasing sector: 0x00000040
    Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (3248 ms). Workaround: increase "set remotetimeout" in GDB
    Info : Programming FLASH (2 sections, 525720 bytes)...
    Info : Programming FLASH section 1/2 (204 bytes) at 0x00400000...
    Info : Padding image section 0 at 0x004000cc with 4 bytes
    Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (24901 ms). Workaround: increase "set remotetimeout" in GDB
    Any idea what could help?
    Best regards,
    Nikolas Becker
    • This topic was modified 4 years, 2 months ago by support. Reason: formatting
    #32818
    This looks like an issue in OpenOCD rather than something VisualGDB-specific. You can try building OpenOCD from sources by following this tutorial, and then step through it to understand what is going on.
    Another option would be to switch to Segger J-Link. It comes with its own fully supported replacement to OpenOCD, that generally works better for many devices.
    If the Atmel IDE works well, you can also try using Process Monitor to to see if uses gdb and whether it launches its own gdb stub similar to OpenOCD. If both are true, and you can run the same stub manually (and connect GDB to it), you can configure VisualGDB to launch it as well by selecting the “Custom GDB stub” mode in VisualGDB Project Properties -> Debug Settings. Note that the last option is something to do at your own risk, as it involves running undocumented Atmel tools.
