Run stm32 target on debugger stop (i.e. Flash and run)
Sysprogs forums Forums VisualGDB Run stm32 target on debugger stop (i.e. Flash and run)
  • #35693
    boazmetry
    How do you make the STM32L496 run post debug – i.e. where the stop button is pressed.
    The only solution I found is setting the STM32 user byte ‘reset after shutdown’.
    Is this the solution or is there another solution?
    #35694
    #35704
    rakesa3590
    hi ,
    I am testing some code on a custom board containing stm32H7 , using visualgdb and segger J-link EDU . using STlink V2 everything works normally. however using J-link debugging works OK , but when I program release version it programs correctly but program doesnot start (I have selected the option reset after programming). even if debugger is removed from board . the only solution is to connect reset to gnd
    info: i am using SWD interface , Reset is connected and verified it is being pulled low briefly during flashing. Also on the custom board the boot 0 is connected to GND using pull down resistor .
    In debug settings/ adavanced settings / startup GDB command :
    target remote:$$SYS:GDB_PORT$$
    mon reset
    load
    mon reset
    What i should add after mon reset to make the target start execution (run) ???
    #35708
