Thanks for renewing your license.
For RP2040 projects there are 2 different FLASH sizes:
- The FLASH size displayed in the Memory Explorer is taken from %VISUALGDB_DIR%\rules\PicoSDK.xml (search for MemoryMap). It is only used to calculate the utilization percentage and can be changed by editing the rule file.
- The actual memory layout is managed by the PicoSDK build system. VisualGDB does not control it directly and lets the PicoSDK manage it.
If you would like to change the actual memory size used for linking, a good starting point would be the default linker script (try adding “-v” to Ninja arguments, re-link the project and search the build log for “.ld” or “-T”). Once you locate the default linker script, you can patch it to have the memory size you prefer, or fork it and patch the PicoSDK CMake files to use the modified version of the script.
