Hello! I can’t find Reset MCU command in the VisualGDB.
Restart works very slow, it makes rebuild and then download it into MCU. But I need just reset it like in Keil.
Currently this is not possible, however if you go to the GDB Session window, select the text input and press the ‘up’ button, it will show the last entered command. Hence, you will just need to press ‘‘ each time you want to execute it.
