Reproducible error
Sysprogs forums Forums VisualGDB Reproducible error
  • #810
    I am debugging software which makes use of fork(). It is possible to get debugging into a frozen state where neither the continue or break buttons are available (and the program continues execution).
    Steps to reproduce:
    1. Break All
    2. Change threads with “inferior 2”
    3. Break All
    This break all never completes, and for this software which contains three forks it is necessary. This is reproducible 100% of the time.
    root@splitice-VirtualBox:~# gdb -v
    GNU gdb (Ubuntu 7.7-0ubuntu3.1) 7.7
    Copyright (C) 2014 Free Software Foundation, Inc.
    #3138
    From a quick look this looks more like a GDB issue. The ‘break all’ simply sends a Ctrl-C event to GDB. You can try experimenting with the set follow-fork-mode command or go to the Custom Debug steps page of VisualGDB Project Properties and override the ‘Break All’ action with a ‘killall -s INT ‘ command to send a SIGINT to all instances you’re debugging.
