Rename not renaming all instances of a macro
Sysprogs forums Forums VisualGDB Rename not renaming all instances of a macro
  • #22205
    nevyn
    I’m just renaming some macro definitions and it looks like the rename is not renaming all instances of the macro.
    File – Messaging.h:
    #define TM_INTERFACE              (0)
    #define TM_FUNCTION               (TM_INTERFACE + 1)
    #define TM_MESSAGE_ID             (TM_FUNCTION + 4)
    #define TM_PAYLOAD_LENGTH         (TM_MESSAGE_ID + 4)
    #define TM_HEADER_LENGTH          (TM_PAYLOAD_LENGTH + 2)
    These definitions are then used through out the application code files.
    I right click on one of the definitions, say TM_INTERFACE, and select <i>Rename</i> from the context menu and the SysProgs rename dialog appears.
    Renaming the macro to APP_REQUEST_INTERFACE results in the following file:
    #define APP_REQUEST_INTERFACE                (0)
    As you can see, the use of TM_INTERFACE in the definition of TM_FUNCTION has not been renamed.
    Regards,
    Mark
    • This topic was modified 7 years, 11 months ago by nevyn.
    #22212
    Thanks, looks like VisualGDB was not properly recording some uses of the macros. Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.4.6.2459.msi
