Raspberry, Header files not found
Sysprogs forums Forums VisualGDB Raspberry, Header files not found
  • #7389
    Nadav
    Environment
    • C++
    • Raspberry Pi2
    • Visual Studio 2015 + VisualGDB 5.0
    Use-case
    • Project is using OpenMAX
    • OpenMAX header files are only found on the ~remote~ Raspberry Pi2 device
    Problem at hand
    1. Trying to go to the definition of any of the OpenMAX APIs ( clicking F12 on Visual Studio ) FAIL with “The selected location does not refer to a C/C++ entity”
    2. Trying to open the header files directly ( by right-clicking the #include command at the C++ Source File ) silently FAILs.
    How can I get ‘Go to Definition’ and ‘IntelliSence’ work for the OpenMAX Header files ( that reside only on the remote RPi2 device ), shouldn’t VisualGDB copy those locally ?
    Nadav @ http://nadavrub.wordpress.com
    • This topic was modified 10 years, 3 months ago by Nadav.
    #7391
    If you are compiling the code on Raspberry Pi, please open VisualGDB Project Properties, go to the IntelliSense Settings page and reload all include directories. If you are using a cross-compiler, simply resynchronize the sysroot from the Build Settings page of VisualGDB Project Properties.
