Putting BSP under the project directory does not work due to bug in bsp.cmake
Sysprogs forums › Forums › VisualGDB › Putting BSP under the project directory does not work due to bug in bsp.cmake
  • #36533
    vedecoid
    When using the EXPLICIT_LOCATION option in the find_bsp function, that location is not taken as the BSP_ROOT when there is any managed BSP defined. As such the function ‘copy BSP to project’ does not work. It copies the BSP but still references the original one.
    The root cause of the fault is an error in bsp.cmake.
    At line 204, the following code never identifies the need to set _load_regular_bsps back to zero if BSP_EXPLICIT_LOCATION is defined, as it should, if VISUALGDB_COMPONENT_LISTS_DIR is not empty (which is never the case if BSPs have been downloaded)
    set(_load_regular_bsps 1)
    if((NOT ("${BSP_EXPLICIT_LOCATION}" STREQUAL "")) OR (NOT ("${BSP_SOURCE}" STREQUAL "")))
    if("${VISUALGDB_COMPONENT_LISTS_DIR}" STREQUAL "")
    set(_load_regular_bsps 0)
    endif()
    endif()
    Resetting _load_regular_bsps to zero when debugging does load the correct local BSP
    Please correct this error in the regular bsp.cmake. I’ve changed it manually for my install, but this will likely break again when doing an upgrade.
    #36534
    vedecoid
    Changing the code to the snippet below seems to correct the error (although I haven’t used it enough to detect potential undesirable side effects)
    if(NOT ("${BSP_EXPLICIT_LOCATION}" STREQUAL ""))
    else()
       if((NOT ("${BSP_SOURCE}" STREQUAL "")))
         endif()
       endif()
    endif()
    #36631
    vedecoid
    Can somebody from VisualGDB support take a look at this ? It’s a documented function that simply does not work without making manual changes to the Sysprogs provided CMake code.
    #36639
    Sorry for the delay. We have rechecked the logic behind BSP_SOURCE, BSP_EXPLICIT_LOCATION and loading of the regular BSPs, and it looks like the regular BSP loading is not necessary when either one is set:
    if((NOT ("${BSP_EXPLICIT_LOCATION}" STREQUAL "")) OR (NOT ("${BSP_SOURCE}" STREQUAL "")) )
    endif()
    We have updated the code on our side and will include it in the next VisualGDB update after it passes all tests.
