Sysprogs forums › Forums › VisualGDB › Project property page not showing c++ and linker properties
- This topic has 5 replies, 2 voices, and was last updated 3 years, 7 months ago by
September 7, 2022 at 15:59 #33141
paulh001
ParticipantI have created a new cmake project with VisualGDB wizard and want to config compiler and linker settings, but in the project property page there a now compiler and linker options visible. I remember this always has worked in the past. Also msbuild new project do not work correct. However old project created in the past still have the properties.
Microsoft Visual Studio Community 2022
Version 17.3.3
VisualStudio.17.Release/17.3.3+32825.248
Microsoft .NET Framework
Version 4.8.04161Installed Version: Community
Visual C++ 2022 00482-90000-00000-AA026
Microsoft Visual C++ 2022Arduino IDE for Visual Studio by Visual Micro 22.0
Visual Micro is an Arduino Compatible IDE for Visual Studio 2022. For more information and forum please visit http://www.visualmicro.com.ASP.NET and Web Tools 17.3.376.3011
ASP.NET and Web ToolsAzure App Service Tools v3.0.0 17.3.376.3011
Azure App Service Tools v3.0.0C# Tools 4.3.0-3.22423.10+b35bb0baca1071d50cc4f8cf5a1a89e7cc112461
C# components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.Cookiecutter 17.0.22179.3
Provides tools for finding, instantiating and customizing templates in cookiecutter format.Linux Core Dump Debugging 1.0.9.32708
Enables debugging of Linux core dumps.Microsoft JVM Debugger 1.0
Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual MachinesNuGet Package Manager 6.3.0
NuGet Package Manager in Visual Studio. For more information about NuGet, visit https://docs.nuget.org/Python – Profiling support 17.0.22179.3
Profiling support for Python projects.Python with Pylance 17.0.22179.3
Provides IntelliSense, projects, templates, debugging, interactive windows, and other support for Python developers.Test Adapter for Boost.Test 1.0
Enables Visual Studio’s testing tools with unit tests written for Boost.Test. The use terms and Third Party Notices are available in the extension installation directory.Test Adapter for Google Test 1.0
Enables Visual Studio’s testing tools with unit tests written for Google Test. The use terms and Third Party Notices are available in the extension installation directory.TypeScript Tools 17.0.10701.2001
TypeScript Tools for Microsoft Visual StudioVisual Basic Tools 4.3.0-3.22423.10+b35bb0baca1071d50cc4f8cf5a1a89e7cc112461
Visual Basic components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.Visual C++ for Linux Development 1.0.9.32708
Visual C++ for Linux DevelopmentVisual Studio IntelliCode 2.2
AI-assisted development for Visual Studio.VisualGDB 5.6
Allows developing and debugging Embedded, Linux, Android and other GCC/GDB-based applications with Visual Studio.September 7, 2022 at 16:02 #33142support
September 8, 2022 at 13:19 #33152paulh001
ParticipantHello,
The steps I took were.
- Start Visual studio
- select new project
- select template linux visualgdb
- Select CMake / Ninja
- after project is created try to open project properties (Menu project -> properties)
- Dialog box appears but without any properties for compiler and linker
See attachment
This reply was modified 3 years, 7 months ago by
paulh001.
You must be logged in to view attached files.September 8, 2022 at 13:23 #33153support
September 8, 2022 at 14:08 #33157paulh001
ParticipantSo, you cannot set compiler and linker settings like you can with MSBUILD.
That would be a disappointment.
You must be logged in to view attached files.September 8, 2022 at 14:09 #33159support
KeymasterYou can if you follow the steps outlined in the documentation and tutorials. If you are doing something different from the steps suggested in the documentation, you will inevitably get different results.
We have asked you to provide the steps to reproduce the issue beginning from VS launch, accompanied by the uncropped screenshots, so that we could point out what you are doing incorrectly. Instead, you have provided ambiguous steps and attached 3 instances of the same cropped screenshot that does not show sufficient context.
We will not be able to help you based on the information you provided and have to close the issue. If you require further help, please do read and follow our problem reporting guidelines. We will not be able to provide any further replies unless you provide the information we requested.
