Sysprogs forums › Forums › VisualGDB › Project doesn't work latest esp32 toolchain update
- This topic has 3 replies, 2 voices, and was last updated 6 years, 9 months ago by
November 28, 2019 at 14:23 #26613
angel
ParticipantI deleted old visualgdbcache files etc.
visual gdb version is v5.5 P1 3292
Log:
– Checking Python dependencies…
Python requirements from c:/SysGCC/esp32/esp-idf/v4.0\requirements.txt are satisfied.
CMake Warning at C:/SysGCC/esp32/esp-idf/v4.0/tools/cmake/crosstool_version_check.cmake:28 (message):
Xtensa toolchain
C:/SysGCC/esp32/opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
crosstool-ng version esp-2019r2 doesn’t match supported version
esp32-2019r1. Check Getting Started documentation or proceed at own risk.
C:/SysGCC/esp32/esp-idf/v4.0/components/esp32/project_include.cmake:21 (crosstool_version_check)
C:/SysGCC/esp32/esp-idf/v4.0/tools/cmake/build.cmake:287 (include)
C:/SysGCC/esp32/esp-idf/v4.0/tools/cmake/build.cmake:440 (__build_process_project_includes)
C:/SysGCC/esp32/esp-idf/v4.0/tools/cmake/project.cmake:341 (idf_build_process)
CMakeLists.txt:6 (project)November 28, 2019 at 20:40 #26635support
KeymasterThis looks like a warning from the ESP-IDF that expects an earlier toolchain version. It should normally not affect the build.
Either way, we have just updated our toolchain to include the latest fixes to ESP-IDF 4.0, that should also eliminate this message. You can re-download it from http://gnutoolchains.com/esp32/
November 29, 2019 at 08:51 #26639angel
ParticipantH,
doesn’t change anything. i deleted cache file etc. nothing changed.
The system is: Windows – 10.0.18362 – AMD64
Compiling the C compiler identification source file “CMakeCCompilerId.c” succeeded.
Compiler: C:/SysGCC/esp32/usr/bin/cc.exe
Build flags:
Id flags:The output was:
0Compilation of the C compiler identification source “CMakeCCompilerId.c” produced “a.exe”
The C compiler identification is GNU, found in “C:/Users/xxxxx/source/embed/Company.Embedded/Demo/SDKDemo/VisualGDB/Debug/CMakeFiles/3.15.2/CompilerIdC/a.exe”
Compiling the CXX compiler identification source file “CMakeCXXCompilerId.cpp” succeeded.
Compiler: C:/SysGCC/esp32/usr/bin/c++.exe
Build flags:
0Compilation of the CXX compiler identification source “CMakeCXXCompilerId.cpp” produced “a.exe”
The CXX compiler identification is GNU, found in “C:/Users/xxxxx/source/embed/Company.Embedded/Demo/SDKDemo/VisualGDB/Debug/CMakeFiles/3.15.2/CompilerIdCXX/a.exe”
Determining if the C compiler works passed with the following output:
Change Dir: C:/Users/xxxxx/source/embed/Company.Embedded/Demo/SDKDemo/VisualGDB/Debug/CMakeFiles/CMakeTmpRun Build Command(s):C:/Program Files (x86)/Sysprogs/VisualGDB/ninja.exe cmTC_5c31b && [1/2] Building C object CMakeFiles/cmTC_5c31b.dir/testCCompiler.c.obj
[2/2] Linking C executable cmTC_5c31b.exe
Detecting C compiler ABI info compiled with the following output:
Change Dir: C:/Users/xxxxx/source/embed/Company.Embedded/Demo/SDKDemo/VisualGDB/Debug/CMakeFiles/CMakeTmpRun Build Command(s):C:/Program Files (x86)/Sysprogs/VisualGDB/ninja.exe cmTC_60cdb && [1/2] Building C object CMakeFiles/cmTC_60cdb.dir/CMakeCCompilerABI.c.obj
Using built-in specs.
COLLECT_GCC=/usr/bin/cc
Target: i686-pc-msys
Configured with: /msys_scripts/gcc/src/gcc-7.4.0/configure –build=i686-pc-msys –prefix=/usr –libexecdir=/usr/lib –enable-bootstrap –enable-shared –enable-shared-libgcc –enable-static –enable-version-specific-runtime-libs –with-arch=i686 –with-tune=generic –disable-multilib –disable-sjlj-exceptions –enable-__cxa_atexit –with-dwarf2 –enable-languages=c,c++,fortran,lto –enable-graphite –enable-threads=posix –enable-libatomic –enable-libcilkrts –enable-libgomp –enable-libitm –enable-libquadmath –enable-libquadmath-support –disable-libssp –disable-win32-registry –disable-symvers –with-gnu-ld –with-gnu-as –disable-isl-version-check –enable-checking=release –without-libiconv-prefix –without-libintl-prefix –with-system-zlib –enable-linker-build-id –with-default-libstdcxx-abi=gcc4-compatible
Thread model: posix
gcc version 7.4.0 (GCC)
COLLECT_GCC_OPTIONS=’-v’ ‘-o’ ‘CMakeFiles/cmTC_60cdb.dir/CMakeCCompilerABI.c.obj’ ‘-c’ ‘-mtune=generic’ ‘-march=i686’
/usr/lib/gcc/i686-pc-msys/7.4.0/cc1.exe -quiet -v -Dunix -idirafter /usr/lib/../include/w32api -idirafter /usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/lib/../../include/w32api C:/Users/xxxxx/AppData/Local/VisualGDB/CMake/share/cmake-3.15/Modules/CMakeCCompilerABI.c -quiet -dumpbase CMakeCCompilerABI.c -mtune=generic -march=i686 -auxbase-strip CMakeFiles/cmTC_60cdb.dir/CMakeCCompilerABI.c.obj -version -o /c/Users/xxxxx/AppData/Local/Temp/ccfuV5Ib.s
GNU C11 (GCC) version 7.4.0 (i686-pc-msys)
compiled by GNU C version 7.4.0, GMP version 6.1.2, MPFR version 4.0.1, MPC version 1.1.0, isl version isl-0.19-GMPwarning: MPFR header version 4.0.1 differs from library version 4.0.2.
GGC heuristics: –param ggc-min-expand=100 –param ggc-min-heapsize=131072
ignoring nonexistent directory “/usr/local/include”
ignoring nonexistent directory “/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/include”
ignoring duplicate directory “/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/lib/../../include/w32api”
#include “…” search starts here:
#include <…> search starts here:
/usr/lib/gcc/i686-pc-msys/7.4.0/include
/usr/lib/gcc/i686-pc-msys/7.4.0/include-fixed
/usr/include
End of search list.
Compiler executable checksum: 0c63ca747ba0801e1e00630431b9d82c
COLLECT_GCC_OPTIONS=’-v’ ‘-o’ ‘CMakeFiles/cmTC_60cdb.dir/CMakeCCompilerABI.c.obj’ ‘-c’ ‘-mtune=generic’ ‘-march=i686′
/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/bin/as.exe -v -o CMakeFiles/cmTC_60cdb.dir/CMakeCCompilerABI.c.obj /c/Users/xxxxx/AppData/Local/Temp/ccfuV5Ib.s
GNU assembler version 2.30 (i686-pc-msys) using BFD version (GNU Binutils) 2.30
COMPILER_PATH=/usr/lib/gcc/i686-pc-msys/7.4.0/:/usr/lib/gcc/i686-pc-msys/7.4.0/:/usr/lib/gcc/i686-pc-msys/:/usr/lib/gcc/i686-pc-msys/7.4.0/:/usr/lib/gcc/i686-pc-msys/:/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/bin/
LIBRARY_PATH=/usr/lib/gcc/i686-pc-msys/7.4.0/:/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/lib/:/usr/lib/:/usr/lib/w32api/
[2/2] Linking C executable cmTC_60cdb.exeUsing built-in specs.
COLLECT_LTO_WRAPPER=/usr/lib/gcc/i686-pc-msys/7.4.0/lto-wrapper.exe
Thread model: posix
COLLECT_GCC_OPTIONS=’-v’ ‘-o’ ‘cmTC_60cdb.exe’ ‘-mtune=generic’ ‘-march=i686′
/usr/lib/gcc/i686-pc-msys/7.4.0/collect2.exe -plugin /usr/lib/gcc/i686-pc-msys/7.4.0/msys-lto_plugin.dll -plugin-opt=/usr/lib/gcc/i686-pc-msys/7.4.0/lto-wrapper.exe -plugin-opt=-fresolution=/c/Users/xxxxx/AppData/Local/Temp/ccmEas0A.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lmsys-2.0 -plugin-opt=-pass-through=-ladvapi32 -plugin-opt=-pass-through=-lshell32 -plugin-opt=-pass-through=-luser32 -plugin-opt=-pass-through=-lkernel32 -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc –build-id –wrap _Znwj –wrap _Znaj –wrap _ZdlPv –wrap _ZdaPv –wrap _ZnwjRKSt9nothrow_t –wrap _ZnajRKSt9nothrow_t –wrap _ZdlPvRKSt9nothrow_t –wrap _ZdaPvRKSt9nothrow_t -Bdynamic –dll-search-prefix=msys- –large-address-aware –tsaware -o cmTC_60cdb.exe /usr/lib/crt0.o /usr/lib/gcc/i686-pc-msys/7.4.0/crtbegin.o -L/usr/lib/gcc/i686-pc-msys/7.4.0 -L/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/lib -L/usr/lib/w32api CMakeFiles/cmTC_60cdb.dir/CMakeCCompilerABI.c.obj –out-implib libcmTC_60cdb.dll.a –major-image-version 0 –minor-image-version 0 -lgcc_s –undefined=___deregister_frame_info –undefined=___register_frame_info -lgcc -lmsys-2.0 -ladvapi32 -lshell32 -luser32 -lkernel32 -lgcc_s –undefined=___deregister_frame_info –undefined=___register_frame_info -lgcc /usr/lib/default-manifest.o /usr/lib/gcc/i686-pc-msys/7.4.0/crtend.o
COLLECT_GCC_OPTIONS=’-v’ ‘-o’ ‘cmTC_60cdb.exe’ ‘-mtune=generic’ ‘-march=i686’Parsed C implicit include dir info from above output: rv=done
found start of include info
found start of implicit include info
add: [/usr/lib/gcc/i686-pc-msys/7.4.0/include]
add: [/usr/lib/gcc/i686-pc-msys/7.4.0/include-fixed]
add: [/usr/include]
add: [/usr/lib/../include/w32api]
end of search list found
collapse include dir [/usr/lib/gcc/i686-pc-msys/7.4.0/include] ==> [/usr/lib/gcc/i686-pc-msys/7.4.0/include]
collapse include dir [/usr/lib/gcc/i686-pc-msys/7.4.0/include-fixed] ==> [/usr/lib/gcc/i686-pc-msys/7.4.0/include-fixed]
collapse include dir [/usr/include] ==> [/usr/include]
collapse include dir [/usr/lib/../include/w32api] ==> [/usr/include/w32api]
implicit include dirs: [/usr/lib/gcc/i686-pc-msys/7.4.0/include;/usr/lib/gcc/i686-pc-msys/7.4.0/include-fixed;/usr/include;/usr/include/w32api]Parsed C implicit link information from above output:
link line regex: [^( *|.*[/\])(ld\.exe|CMAKE_LINK_STARTFILE-NOTFOUND|([^/\]+-)?ld|collect2)[^/\]*( |$)]
ignore line: [Change Dir: C:/Users/xxxxx/source/embed/Company.Embedded/Demo/SDKDemo/VisualGDB/Debug/CMakeFiles/CMakeTmp]
ignore line: []
ignore line: [Run Build Command(s):C:/Program Files (x86)/Sysprogs/VisualGDB/ninja.exe cmTC_60cdb && [1/2] Building C object CMakeFiles/cmTC_60cdb.dir/CMakeCCompilerABI.c.obj]
ignore line: [Using built-in specs.]
ignore line: [COLLECT_GCC=/usr/bin/cc]
ignore line: [Target: i686-pc-msys]
ignore line: [Configured with: /msys_scripts/gcc/src/gcc-7.4.0/configure –build=i686-pc-msys –prefix=/usr –libexecdir=/usr/lib –enable-bootstrap –enable-shared –enable-shared-libgcc –enable-static –enable-version-specific-runtime-libs –with-arch=i686 –with-tune=generic –disable-multilib –disable-sjlj-exceptions –enable-__cxa_atexit –with-dwarf2 –enable-languages=c,c++,fortran,lto –enable-graphite –enable-threads=posix –enable-libatomic –enable-libcilkrts –enable-libgomp –enable-libitm –enable-libquadmath –enable-libquadmath-support –disable-libssp –disable-win32-registry –disable-symvers –with-gnu-ld –with-gnu-as –disable-isl-version-check –enable-checking=release –without-libiconv-prefix –without-libintl-prefix –with-system-zlib –enable-linker-build-id –with-default-libstdcxx-abi=gcc4-compatible]
ignore line: [Thread model: posix]
ignore line: [gcc version 7.4.0 (GCC) ]
ignore line: [COLLECT_GCC_OPTIONS=’-v’ ‘-o’ ‘CMakeFiles/cmTC_60cdb.dir/CMakeCCompilerABI.c.obj’ ‘-c’ ‘-mtune=generic’ ‘-march=i686′]
ignore line: [ /usr/lib/gcc/i686-pc-msys/7.4.0/cc1.exe -quiet -v -Dunix -idirafter /usr/lib/../include/w32api -idirafter /usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/lib/../../include/w32api C:/Users/xxxxx/AppData/Local/VisualGDB/CMake/share/cmake-3.15/Modules/CMakeCCompilerABI.c -quiet -dumpbase CMakeCCompilerABI.c -mtune=generic -march=i686 -auxbase-strip CMakeFiles/cmTC_60cdb.dir/CMakeCCompilerABI.c.obj -version -o /c/Users/xxxxx/AppData/Local/Temp/ccfuV5Ib.s]
ignore line: [GNU C11 (GCC) version 7.4.0 (i686-pc-msys)]
ignore line: [ compiled by GNU C version 7.4.0, GMP version 6.1.2, MPFR version 4.0.1, MPC version 1.1.0, isl version isl-0.19-GMP]
ignore line: []
ignore line: [warning: MPFR header version 4.0.1 differs from library version 4.0.2.]
ignore line: [GGC heuristics: –param ggc-min-expand=100 –param ggc-min-heapsize=131072]
ignore line: [ignoring nonexistent directory “/usr/local/include”]
ignore line: [ignoring nonexistent directory “/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/include”]
ignore line: [ignoring duplicate directory “/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/lib/../../include/w32api”]
ignore line: [#include “…” search starts here:]
ignore line: [#include <…> search starts here:]
ignore line: [ /usr/lib/gcc/i686-pc-msys/7.4.0/include]
ignore line: [ /usr/lib/gcc/i686-pc-msys/7.4.0/include-fixed]
ignore line: [ /usr/include]
ignore line: [ /usr/lib/../include/w32api]
ignore line: [End of search list.]
ignore line: []
ignore line: [Compiler executable checksum: 0c63ca747ba0801e1e00630431b9d82c]
ignore line: [ /usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/bin/as.exe -v -o CMakeFiles/cmTC_60cdb.dir/CMakeCCompilerABI.c.obj /c/Users/xxxxx/AppData/Local/Temp/ccfuV5Ib.s]
ignore line: [GNU assembler version 2.30 (i686-pc-msys) using BFD version (GNU Binutils) 2.30]
ignore line: [COMPILER_PATH=/usr/lib/gcc/i686-pc-msys/7.4.0/:/usr/lib/gcc/i686-pc-msys/7.4.0/:/usr/lib/gcc/i686-pc-msys/:/usr/lib/gcc/i686-pc-msys/7.4.0/:/usr/lib/gcc/i686-pc-msys/:/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/bin/]
ignore line: [LIBRARY_PATH=/usr/lib/gcc/i686-pc-msys/7.4.0/:/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/lib/:/usr/lib/:/usr/lib/w32api/]
ignore line: [[2/2] Linking C executable cmTC_60cdb.exe]
ignore line: [COLLECT_LTO_WRAPPER=/usr/lib/gcc/i686-pc-msys/7.4.0/lto-wrapper.exe]
ignore line: [COLLECT_GCC_OPTIONS=’-v’ ‘-o’ ‘cmTC_60cdb.exe’ ‘-mtune=generic’ ‘-march=i686’]
link line: [ /usr/lib/gcc/i686-pc-msys/7.4.0/collect2.exe -plugin /usr/lib/gcc/i686-pc-msys/7.4.0/msys-lto_plugin.dll -plugin-opt=/usr/lib/gcc/i686-pc-msys/7.4.0/lto-wrapper.exe -plugin-opt=-fresolution=/c/Users/xxxxx/AppData/Local/Temp/ccmEas0A.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lmsys-2.0 -plugin-opt=-pass-through=-ladvapi32 -plugin-opt=-pass-through=-lshell32 -plugin-opt=-pass-through=-luser32 -plugin-opt=-pass-through=-lkernel32 -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc –build-id –wrap _Znwj –wrap _Znaj –wrap _ZdlPv –wrap _ZdaPv –wrap _ZnwjRKSt9nothrow_t –wrap _ZnajRKSt9nothrow_t –wrap _ZdlPvRKSt9nothrow_t –wrap _ZdaPvRKSt9nothrow_t -Bdynamic –dll-search-prefix=msys- –large-address-aware –tsaware -o cmTC_60cdb.exe /usr/lib/crt0.o /usr/lib/gcc/i686-pc-msys/7.4.0/crtbegin.o -L/usr/lib/gcc/i686-pc-msys/7.4.0 -L/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/lib -L/usr/lib/w32api CMakeFiles/cmTC_60cdb.dir/CMakeCCompilerABI.c.obj –out-implib libcmTC_60cdb.dll.a –major-image-version 0 –minor-image-version 0 -lgcc_s –undefined=___deregister_frame_info –undefined=___register_frame_info -lgcc -lmsys-2.0 -ladvapi32 -lshell32 -luser32 -lkernel32 -lgcc_s –undefined=___deregister_frame_info –undefined=___register_frame_info -lgcc /usr/lib/default-manifest.o /usr/lib/gcc/i686-pc-msys/7.4.0/crtend.o]
arg [/usr/lib/gcc/i686-pc-msys/7.4.0/collect2.exe] ==> ignore
arg [-plugin] ==> ignore
arg [/usr/lib/gcc/i686-pc-msys/7.4.0/msys-lto_plugin.dll] ==> ignore
arg [-plugin-opt=/usr/lib/gcc/i686-pc-msys/7.4.0/lto-wrapper.exe] ==> ignore
arg [-plugin-opt=-fresolution=/c/Users/xxxxx/AppData/Local/Temp/ccmEas0A.res] ==> ignore
arg [-plugin-opt=-pass-through=-lgcc_s] ==> ignore
arg [-plugin-opt=-pass-through=-lgcc] ==> ignore
arg [-plugin-opt=-pass-through=-lmsys-2.0] ==> ignore
arg [-plugin-opt=-pass-through=-ladvapi32] ==> ignore
arg [-plugin-opt=-pass-through=-lshell32] ==> ignore
arg [-plugin-opt=-pass-through=-luser32] ==> ignore
arg [-plugin-opt=-pass-through=-lkernel32] ==> ignore
arg [–build-id] ==> ignore
arg [–wrap] ==> ignore
arg [_Znwj] ==> ignore
arg [_Znaj] ==> ignore
arg [_ZdlPv] ==> ignore
arg [_ZdaPv] ==> ignore
arg [_ZnwjRKSt9nothrow_t] ==> ignore
arg [_ZnajRKSt9nothrow_t] ==> ignore
arg [_ZdlPvRKSt9nothrow_t] ==> ignore
arg [_ZdaPvRKSt9nothrow_t] ==> ignore
arg [-Bdynamic] ==> ignore
arg [–dll-search-prefix=msys-] ==> ignore
arg [–large-address-aware] ==> ignore
arg [–tsaware] ==> ignore
arg [-o] ==> ignore
arg [cmTC_60cdb.exe] ==> ignore
arg [/usr/lib/crt0.o] ==> ignore
arg [/usr/lib/gcc/i686-pc-msys/7.4.0/crtbegin.o] ==> ignore
arg [-L/usr/lib/gcc/i686-pc-msys/7.4.0] ==> dir [/usr/lib/gcc/i686-pc-msys/7.4.0]
arg [-L/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/lib] ==> dir [/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/lib]
arg [-L/usr/lib/w32api] ==> dir [/usr/lib/w32api]
arg [CMakeFiles/cmTC_60cdb.dir/CMakeCCompilerABI.c.obj] ==> ignore
arg [–out-implib] ==> ignore
arg [libcmTC_60cdb.dll.a] ==> ignore
arg [–major-image-version] ==> ignore
arg [0] ==> ignore
arg [–minor-image-version] ==> ignore
arg [0] ==> ignore
arg [-lgcc_s] ==> lib [gcc_s]
arg [–undefined=___deregister_frame_info] ==> ignore
arg [–undefined=___register_frame_info] ==> ignore
arg [-lgcc] ==> lib [gcc]
arg [-lmsys-2.0] ==> lib [msys-2.0]
arg [-ladvapi32] ==> lib [advapi32]
arg [-lshell32] ==> lib [shell32]
arg [-luser32] ==> lib [user32]
arg [-lkernel32] ==> lib [kernel32]
arg [/usr/lib/default-manifest.o] ==> ignore
arg [/usr/lib/gcc/i686-pc-msys/7.4.0/crtend.o] ==> ignore
collapse library dir [/usr/lib/gcc/i686-pc-msys/7.4.0] ==> [/usr/lib/gcc/i686-pc-msys/7.4.0]
collapse library dir [/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/lib] ==> [/usr/i686-pc-msys/lib]
collapse library dir [/usr/lib/w32api] ==> [/usr/lib/w32api]
implicit libs: [gcc_s;gcc;msys-2.0;advapi32;shell32;user32;kernel32;gcc_s;gcc]
implicit dirs: [/usr/lib/gcc/i686-pc-msys/7.4.0;/usr/i686-pc-msys/lib;/usr/lib/w32api]
implicit fwks: []Determining if the CXX compiler works passed with the following output:
Change Dir: C:/Users/xxxxx/source/embed/Company.Embedded/Demo/SDKDemo/VisualGDB/Debug/CMakeFiles/CMakeTmpRun Build Command(s):C:/Program Files (x86)/Sysprogs/VisualGDB/ninja.exe cmTC_ce0a5 && [1/2] Building CXX object CMakeFiles/cmTC_ce0a5.dir/testCXXCompiler.cxx.o
[2/2] Linking CXX executable cmTC_ce0a5.exe
Detecting CXX compiler ABI info compiled with the following output:
Change Dir: C:/Users/xxxxx/source/embed/Company.Embedded/Demo/SDKDemo/VisualGDB/Debug/CMakeFiles/CMakeTmpRun Build Command(s):C:/Program Files (x86)/Sysprogs/VisualGDB/ninja.exe cmTC_be7dd && [1/2] Building CXX object CMakeFiles/cmTC_be7dd.dir/CMakeCXXCompilerABI.cpp.o
COLLECT_GCC=/usr/bin/c++
Thread model: posix
COLLECT_GCC_OPTIONS=’-v’ ‘-o’ ‘CMakeFiles/cmTC_be7dd.dir/CMakeCXXCompilerABI.cpp.o’ ‘-c’ ‘-shared-libgcc’ ‘-mtune=generic’ ‘-march=i686’
/usr/lib/gcc/i686-pc-msys/7.4.0/cc1plus.exe -quiet -v -D_GNU_SOURCE -Dunix -idirafter /usr/lib/../include/w32api -idirafter /usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/lib/../../include/w32api C:/Users/xxxxx/AppData/Local/VisualGDB/CMake/share/cmake-3.15/Modules/CMakeCXXCompilerABI.cpp -quiet -dumpbase CMakeCXXCompilerABI.cpp -mtune=generic -march=i686 -auxbase-strip CMakeFiles/cmTC_be7dd.dir/CMakeCXXCompilerABI.cpp.o -version -o /c/Users/xxxxx/AppData/Local/Temp/ccu1p4XA.s
GNU C++14 (GCC) version 7.4.0 (i686-pc-msys)
/usr/lib/gcc/i686-pc-msys/7.4.0/include/c++
/usr/lib/gcc/i686-pc-msys/7.4.0/include/c++/i686-pc-msys
/usr/lib/gcc/i686-pc-msys/7.4.0/include/c++/backward
/usr/include
End of search list.
Compiler executable checksum: dc8967e5ff94710848e7b53784d60a18
COLLECT_GCC_OPTIONS=’-v’ ‘-o’ ‘CMakeFiles/cmTC_be7dd.dir/CMakeCXXCompilerABI.cpp.o’ ‘-c’ ‘-shared-libgcc’ ‘-mtune=generic’ ‘-march=i686′
/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/bin/as.exe -v -o CMakeFiles/cmTC_be7dd.dir/CMakeCXXCompilerABI.cpp.o /c/Users/xxxxx/AppData/Local/Temp/ccu1p4XA.s
[2/2] Linking CXX executable cmTC_be7dd.exeUsing built-in specs.
Thread model: posix
COLLECT_GCC_OPTIONS=’-v’ ‘-o’ ‘cmTC_be7dd.exe’ ‘-shared-libgcc’ ‘-mtune=generic’ ‘-march=i686′
/usr/lib/gcc/i686-pc-msys/7.4.0/collect2.exe -plugin /usr/lib/gcc/i686-pc-msys/7.4.0/msys-lto_plugin.dll -plugin-opt=/usr/lib/gcc/i686-pc-msys/7.4.0/lto-wrapper.exe -plugin-opt=-fresolution=/c/Users/xxxxx/AppData/Local/Temp/ccqxSYdU.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lmsys-2.0 -plugin-opt=-pass-through=-ladvapi32 -plugin-opt=-pass-through=-lshell32 -plugin-opt=-pass-through=-luser32 -plugin-opt=-pass-through=-lkernel32 -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc –build-id –wrap _Znwj –wrap _Znaj –wrap _ZdlPv –wrap _ZdaPv –wrap _ZnwjRKSt9nothrow_t –wrap _ZnajRKSt9nothrow_t –wrap _ZdlPvRKSt9nothrow_t –wrap _ZdaPvRKSt9nothrow_t -Bdynamic –dll-search-prefix=msys- –large-address-aware –tsaware -o cmTC_be7dd.exe /usr/lib/crt0.o /usr/lib/gcc/i686-pc-msys/7.4.0/crtbegin.o -L/usr/lib/gcc/i686-pc-msys/7.4.0 -L/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/lib -L/usr/lib/w32api CMakeFiles/cmTC_be7dd.dir/CMakeCXXCompilerABI.cpp.o –out-implib libcmTC_be7dd.dll.a –major-image-version 0 –minor-image-version 0 -lstdc++ -lgcc_s –undefined=___deregister_frame_info –undefined=___register_frame_info -lgcc -lmsys-2.0 -ladvapi32 -lshell32 -luser32 -lkernel32 -lgcc_s –undefined=___deregister_frame_info –undefined=___register_frame_info -lgcc /usr/lib/default-manifest.o /usr/lib/gcc/i686-pc-msys/7.4.0/crtend.o
COLLECT_GCC_OPTIONS=’-v’ ‘-o’ ‘cmTC_be7dd.exe’ ‘-shared-libgcc’ ‘-mtune=generic’ ‘-march=i686’Parsed CXX implicit include dir info from above output: rv=done
add: [/usr/lib/gcc/i686-pc-msys/7.4.0/include/c++]
add: [/usr/lib/gcc/i686-pc-msys/7.4.0/include/c++/i686-pc-msys]
add: [/usr/lib/gcc/i686-pc-msys/7.4.0/include/c++/backward]
add: [/usr/include]
collapse include dir [/usr/lib/gcc/i686-pc-msys/7.4.0/include/c++] ==> [/usr/lib/gcc/i686-pc-msys/7.4.0/include/c++]
collapse include dir [/usr/lib/gcc/i686-pc-msys/7.4.0/include/c++/i686-pc-msys] ==> [/usr/lib/gcc/i686-pc-msys/7.4.0/include/c++/i686-pc-msys]
collapse include dir [/usr/lib/gcc/i686-pc-msys/7.4.0/include/c++/backward] ==> [/usr/lib/gcc/i686-pc-msys/7.4.0/include/c++/backward]
implicit include dirs: [/usr/lib/gcc/i686-pc-msys/7.4.0/include/c++;/usr/lib/gcc/i686-pc-msys/7.4.0/include/c++/i686-pc-msys;/usr/lib/gcc/i686-pc-msys/7.4.0/include/c++/backward;/usr/lib/gcc/i686-pc-msys/7.4.0/include;/usr/lib/gcc/i686-pc-msys/7.4.0/include-fixed;/usr/include;/usr/include/w32api]Parsed CXX implicit link information from above output:
ignore line: []
ignore line: [Run Build Command(s):C:/Program Files (x86)/Sysprogs/VisualGDB/ninja.exe cmTC_be7dd && [1/2] Building CXX object CMakeFiles/cmTC_be7dd.dir/CMakeCXXCompilerABI.cpp.o]
ignore line: [COLLECT_GCC=/usr/bin/c++]
ignore line: [COLLECT_GCC_OPTIONS=’-v’ ‘-o’ ‘CMakeFiles/cmTC_be7dd.dir/CMakeCXXCompilerABI.cpp.o’ ‘-c’ ‘-shared-libgcc’ ‘-mtune=generic’ ‘-march=i686′]
ignore line: [ /usr/lib/gcc/i686-pc-msys/7.4.0/cc1plus.exe -quiet -v -D_GNU_SOURCE -Dunix -idirafter /usr/lib/../include/w32api -idirafter /usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/lib/../../include/w32api C:/Users/xxxxx/AppData/Local/VisualGDB/CMake/share/cmake-3.15/Modules/CMakeCXXCompilerABI.cpp -quiet -dumpbase CMakeCXXCompilerABI.cpp -mtune=generic -march=i686 -auxbase-strip CMakeFiles/cmTC_be7dd.dir/CMakeCXXCompilerABI.cpp.o -version -o /c/Users/xxxxx/AppData/Local/Temp/ccu1p4XA.s]
ignore line: [GNU C++14 (GCC) version 7.4.0 (i686-pc-msys)]
ignore line: []
ignore line: [ /usr/lib/gcc/i686-pc-msys/7.4.0/include/c++]
ignore line: [ /usr/lib/gcc/i686-pc-msys/7.4.0/include/c++/i686-pc-msys]
ignore line: [ /usr/lib/gcc/i686-pc-msys/7.4.0/include/c++/backward]
ignore line: []
ignore line: [Compiler executable checksum: dc8967e5ff94710848e7b53784d60a18]
ignore line: [ /usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/bin/as.exe -v -o CMakeFiles/cmTC_be7dd.dir/CMakeCXXCompilerABI.cpp.o /c/Users/xxxxx/AppData/Local/Temp/ccu1p4XA.s]
ignore line: [[2/2] Linking CXX executable cmTC_be7dd.exe]
ignore line: [COLLECT_GCC_OPTIONS=’-v’ ‘-o’ ‘cmTC_be7dd.exe’ ‘-shared-libgcc’ ‘-mtune=generic’ ‘-march=i686’]
link line: [ /usr/lib/gcc/i686-pc-msys/7.4.0/collect2.exe -plugin /usr/lib/gcc/i686-pc-msys/7.4.0/msys-lto_plugin.dll -plugin-opt=/usr/lib/gcc/i686-pc-msys/7.4.0/lto-wrapper.exe -plugin-opt=-fresolution=/c/Users/xxxxx/AppData/Local/Temp/ccqxSYdU.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lmsys-2.0 -plugin-opt=-pass-through=-ladvapi32 -plugin-opt=-pass-through=-lshell32 -plugin-opt=-pass-through=-luser32 -plugin-opt=-pass-through=-lkernel32 -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc –build-id –wrap _Znwj –wrap _Znaj –wrap _ZdlPv –wrap _ZdaPv –wrap _ZnwjRKSt9nothrow_t –wrap _ZnajRKSt9nothrow_t –wrap _ZdlPvRKSt9nothrow_t –wrap _ZdaPvRKSt9nothrow_t -Bdynamic –dll-search-prefix=msys- –large-address-aware –tsaware -o cmTC_be7dd.exe /usr/lib/crt0.o /usr/lib/gcc/i686-pc-msys/7.4.0/crtbegin.o -L/usr/lib/gcc/i686-pc-msys/7.4.0 -L/usr/lib/gcc/i686-pc-msys/7.4.0/../../../../i686-pc-msys/lib -L/usr/lib/w32api CMakeFiles/cmTC_be7dd.dir/CMakeCXXCompilerABI.cpp.o –out-implib libcmTC_be7dd.dll.a –major-image-version 0 –minor-image-version 0 -lstdc++ -lgcc_s –undefined=___deregister_frame_info –undefined=___register_frame_info -lgcc -lmsys-2.0 -ladvapi32 -lshell32 -luser32 -lkernel32 -lgcc_s –undefined=___deregister_frame_info –undefined=___register_frame_info -lgcc /usr/lib/default-manifest.o /usr/lib/gcc/i686-pc-msys/7.4.0/crtend.o]
arg [-plugin-opt=-fresolution=/c/Users/xxxxx/AppData/Local/Temp/ccqxSYdU.res] ==> ignore
arg [-o] ==> ignore
arg [cmTC_be7dd.exe] ==> ignore
arg [CMakeFiles/cmTC_be7dd.dir/CMakeCXXCompilerABI.cpp.o] ==> ignore
arg [libcmTC_be7dd.dll.a] ==> ignore
arg [0] ==> ignore
arg [0] ==> ignore
arg [-lstdc++] ==> lib [stdc++]
implicit libs: [stdc++;gcc_s;gcc;msys-2.0;advapi32;shell32;user32;kernel32;gcc_s;gcc]
implicit fwks: []November 29, 2019 at 16:46 #26657support
KeymasterSorry, we were not able to reproduce the problem. We have tried creating a new project from scratch using the new toolchain and it worked.
Most likely, the issue you are experiencing is caused by incompatibility between the toolchain and a specific project, or some corrupt files. Please consider posting the logs on the Espressif forum to get further help on this.
