program doesn't work without debugger
Sysprogs forums Forums VisualGDB program doesn't work without debugger
  • #9417
    bondarenkod
    <div>Hello!
    I have a problem with VisualGDB.</div>
    <div>Couple days ago any programs from VS stopped working on my two demo boards without connected debug.
    I tried to test it from 2 laptops – the same result (5.1 (or 5.0) and 5.2 VisualGDB).
    With connected debugger program working properly.
    Demo application from discovery 429i also working (via hex flashing)/
    Here is sample video: https://www.youtube.com/watch?v=SONL2pnnkUE</div&gt;
    #9418
    bondarenkod
    demo application
    #9422
    Are you using semihosting in your programs? The way semihosting works would cause the program to stop if a debugger is not attached. Please try making the calls to printf() and other semihosting-related functions conditional so that they don’t trigger in the release configuration.
    #9433
    bondarenkod
    yes. But not in this sample and actual post not about problem with semihosting.
    Yes, I also have problems with semihosting – in projects with\without mbed. But currently projects with mbed just doesn’t work without connected debugger.
    This project just basic project, which created by VisualGDB and doesn’t contains any changes which made by me (only few lines to make leds blinking). I can record step-by-step the process to show you almost everything. Project without mbed is working OK.
    • This reply was modified 9 years, 4 months ago by bondarenkod.
    #9436
    bondarenkod
    Ok, I found that in the project with MBED the VS window called ‘ARM semihosting console’ still empty, but COM Terminal window working perfectly.
    Problem #1 – Pending.
    Problem #2 – Sovled.
    #9441
    Please try updating to the latest gcc 6.3.0-r3 toolchain. We have fixed a problem that might have been causing this.
    #9443
    bondarenkod
    Yep! Now it’s working as expected! Thank you 🙂
