Profiler stuck in ReturnHook function
Sysprogs forums › Forums › VisualGDB › Profiler stuck in ReturnHook function
  • #31048
    curtis.hendrix
    I’m trying to profile my firmware, and the firmware falls into a loop in the profiler.  The call stack only goes back to SysprogsInstrumentingProfiler::ReturnHook.
    It appears to be a problem with interrupts.  I have a SysTick interrupt and an ADC interrupt.  SysTick goes off every millisecond.  The ADC triggers every 50µsec.  The profiler works when all interrupts are disabled.
    #31050
    curtis.hendrix
    This appears to be an issue only when the SysTick handler is instrumented for profiling.
    #31055
    Instrumenting functions for profiling changes their timing and also increases the stack footprint (the code that outputs profiling information takes extra time and requires non-trivial amounts of stack). Most likely, in your scenario this triggers a stack overflow, or makes the interrupt handler run longer than the period between the interrupts.
    Unfortunately, there is no fully automated way to troubleshoot such issues. Our best advice would be to try excluding some functions from instrumentation, and to experiment with increasing the stack size and decreasing the complexity of the affected functions.
