Sysprogs forums › Forums › VisualGDB › Problem on new ESP32 toolchain
- This topic has 3 replies, 2 voices, and was last updated 1 year, 7 months ago by
August 26, 2024 at 00:43 #35938
lisa.tamanti@faacgroup.com
ParticipantI installed ESP32 toolchain 13.2.0/14.2/r2, OpenOCD 20240820-0.12.0, cmake 3.28.1, Python 3.11.5
I try to create a new Visual GDB Project project starting from hello_world and at the fourth step “Debug Method” I obtein this without to have the possibility to select ESP32 DevKit
System.Exception: Per il componente ‘ESP8266DebugPackage.GUI.ESPxxOpenOCDSettingsControl’ non è disponibile una risorsa identificata dall’URI ‘/ESPxxDebugPackage;V2.0.5454.0;component/gui/espxxopenocdsettingscontrol.xaml’.
in System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
in ESP8266DebugPackage.GUI.ESPxxOpenOCDSettingsControl.InitializeComponent()
in ESP8266DebugPackage.GUI.ESPxxOpenOCDSettingsControl..ctor(LoadedDebugMethod method, IBSPConfiguratorHost host, ESPxxDebugController controller, Boolean isESP32)
in ESP8266DebugPackage.ESPxxDebugController.CreateConfigurator(LoadedDebugMethod method, IBSPConfiguratorHost host)
in VisualGDB.Common_GUI.WPF.DebugMethodSettingsControl.Controller.BoundDebugMethod.ProvideConfiguratorOrThrow(IBSPConfiguratorHost host)
in VisualGDB.Common_GUI.WPF.DebugMethodSettingsControl.Controller.UpdateSelectedConfigurator(Boolean suppressPropertyChangeHandlers, MethodOrDeviceItemBase value, MethodOrDeviceItemBase prevValue)What I did wrong?
Thank you very much for your help!!
You must be logged in to view attached files.August 26, 2024 at 02:12 #35940lisa.tamanti@faacgroup.com
ParticipantNow I succeded on it but when I create the project I have this error:
— Could not use ‘git describe’ to determine PROJECT_VER.
— Building ESP-IDF components for target esp32
— Checking Python dependencies…
The following Python requirements are not satisfied:
Requirement ‘idf-component-manager~=1.2’ was not met. Installed version: 2.0.2
To install the missing packages, please run “install.bat”
Diagnostic information:
IDF_PYTHON_ENV_PATH: C:\Espressif\python_env\\idf5.2_py3.8_env
Python interpreter used: C:\Espressif\python_env\idf5.2_py3.8_env\Scripts\python.exe
Warning: python interpreter not running from IDF_PYTHON_ENV_PATH
PATH: C:\Program Files\Git\cmd;C:\Espressif\python_env\\idf5.2_py3.8_env\Scripts;C:\Users\bope02\AppData\Local\VisualGDB\Python-3.8.10;C:\SysGCC_R1\tools\xtensa-esp-elf\esp-13.2.0_20230928\xtensa-esp-elf\bin;C:\SysGCC_R1\tools\xtensa-esp-elf\esp-13.2.0_20230928\xtensa-esp-elf\bin;C:\SysGCC_R1\tools\esp32ulp-elf\2.35_20220830\esp32ulp-elf\bin;C:\SysGCC_R1\tools\riscv32-esp-elf\esp-13.2.0_20230928\riscv32-esp-elf\bin;C:\SysGCC_R1\tools\idf-exe\1.0.3;C:\SysGCC_R1\tools\ccache\4.8\ccache-4.8-windows-x86_64;C:\SysGCC_R1\tools\ninja\1.11.1;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn\;C:\Program Files\Git\cmd;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\dotnet\;C:\Users\bope02\AppData\Local\Microsoft\WindowsApps;
Constraint file: C:\Users\bope02\.espressif\espidf.constraints.v5.2.txt
Requirement files:
– C:\SysGCC_R1\esp-idf\v5.2\tools\requirements\requirements.core.txt
Python being checked: C:\Espressif\python_env\\idf5.2_py3.8_env\Scripts\python.exe
— Configuring incomplete, errors occurred!
CMake Error at C:/SysGCC_R1/esp-idf/v5.2/tools/cmake/build.cmake:368 (message):
Failed to run Python dependency check. Python: python, Error: -1I reinstalled Python 3.11.5 from Manage VisualGDB Packages (see attached) but without resolving problems…
You must be logged in to view attached files.August 26, 2024 at 04:25 #35942lisa.tamanti@faacgroup.com
ParticipantI tryed to use the Resetting Python Environment as explained here: https://visualgdb.com/documentation/python/ without solving:
From the message that I reported in my previous comment I see:
How can correct this path if I have canceled path from Tools->Options->VisualGDB->General->Python Directory ?
August 26, 2024 at 10:07 #35943support
The first error looks like a corrupt package or too old VisualGDB version. Installing the latest VisualGDB 6.0 should solve the problem.
The second one looks like the Python environment is corrupt or incompatible with the ESP-IDF version you are using. Please try completely resetting the toolchain as shown here.
Normally, as long as you clear the Python path, VisualGDB will automatically start using the one from %LOCALAPPDATA%\VisualGDB\Python-<Version>. However, if you had previously installed some extra packages into it, it could break compatibility with ESP-IDF. Please make sure you delete the Python directory when you reset the Python environment, and let VisualGDB re-download a clean one from scratch.
