Hello all,
I am Using Win10 64bit with VS2017 community.
JTAG debugger is ARM-USB TINY from Olimex
When i test connection with Olimex ,ESP32-EVB i have got the following eror message:
C:\SysGCC\esp32\esp32-bsp\OpenOCD\bin\openocd.exe -c "gdb_port 61847" -c "telnet_port 61848" -f interface/ftdi/olimex-arm-usb-tiny-h.cfg -f target/esp32.cfg -c "adapter_khz 3000" -c "echo VisualGDB_OpenOCD_Ready"
Open On-Chip Debugger 0.9.0 (2017-08-05)
Licensed under GNU GPL v2
For bug reports, read
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
force hard breakpoints
adapter speed: 3000 kHz
Error: no device found
Error: unable to open ftdi device with vid 15ba, pid 002a, description 'Olimex OpenOCD JTAG ARM-USB-TINY-H', serial '*' at bus location '*'
What may cause this error:
What are correct settings of adapter within deice manager, wich driver to use, VisualGDB settings ?
See Attachments
Thanks in advance
Marc
<div class=”product-details”></div>
You must be
