Pre-Build Steps missing from Properties
Sysprogs forums Forums VisualGDB Pre-Build Steps missing from Properties
  • #23320
    canaanav
    I cannot find the prebuild step interface as described in project properties documentation. I need to run an executable before build.  I think I had an earlier version and it was available and worked.  Was the feature removed?
    Using VGB Embedded Edition, version 5.4.
    #23321
    Sorry, this is by design. This feature is available starting from the Custom edition of VisualGDB. If you are using a lower edition, please consider adding a Make or MSBuild target manually.
    Alternatively, you can update your license to the Custom edition here: https://sysprogs.com/splm/mykey
    #23325
    canaanav
    I tried adding this bit, but I don’t think it’s working.   I’ll find another workaround.  I’ll stick with the version I have for now, still partly evaluating the product.
    <PropertyGroup Label=”UserMacros” />
    <ItemDefinitionGroup>
    <PreBuildEvent>
    <Command>.\Script\TRXM_82.exe </Command>
    <Message>bLA BLA BLA </Message>
    </PreBuildEvent>
    </ItemDefinitionGroup>
    #23327
    Please consider using the MSBuild Exec task instead. It should work regardless of the project type and other VisualGDB-related settings.
