Sysprogs forums › Forums › VisualGDB › Porting RIOT OS GNU MAKE project to VisualGDB
- This topic has 12 replies, 2 voices, and was last updated 5 years, 6 months ago by
Gordon01.
June 26, 2020 at 20:04 #28537
Gordon01
ParticipantI’m trying to migrate to VisualGDB completely, but struggling with some legacy projects.
The project I’m talking about is based on RIOT OS and is configured to be built by basic Autotools and GNU Make, however, I still have problems with it 🙂
I want to migrate one-way and get rid of makefiles.
Also, I have only basic knowledge about Autotools and I don’t fully understand makefiles so this complicates things.
What is the best way to approach this task?
Right now, I’m trying an “Import a project built with command-line tools”.
On a step “run build command” I get this error message from build script:
Aborting compilation for your safety.
Related variables = RIOTBASE RIOTCPU RIOTBOARD RIOTMAKE RIOTPKG RIOTTOOLS RIOTPROJECT APPDIR BUILD_DIR BINDIRBASE BINDIR CCACHE_BASEDIR GITCACHE PKGDIRBASE DLCACHE_DIR
C:/Projects/pwr_meter/apps/pwrmeter/../../Makefile.include:73: *** Make sure no path override is empty or contains spaces!. Stop.also with an error about not found “pwd” command.
We build this project under WSL with just issuing a make command. A compiler is “normal” arm-none-eabi-gcc version 9.3.1
My ultimate goal is this project completely converted to MSBuild format and built without WSL with the latest version of arm-none-eabi-gcc.
You must be logged in to view attached files.June 26, 2020 at 21:07 #28552support
The best way to convert the project into an MSBuild-based one would be to find a way to dump all the gcc command lines used by the current setup (each Makefile handles this differently, so please check the RIOT OS documentation for more details), and then create a new VisualGDB project from scratch and adjust its build settings to match the captured command lines.
You can find the exact command lines used by VisualGDB to build an MSBuild-based project in the .rsp files.
We also have a detailed tutorial on using .rsp files to troubleshoot imported projects here: https://visualgdb.com/tutorials/arm/import/diagnose/
If you do not want to spend time learning the autotools/Make internals, or porting the project from WSL to Windows-based build tools, please try importing the project as a Linux-based project built with external tools under WSL and make sure the manual build command line matches one that is already working. As long as both VisualGDB and the manual build are using WSL, they should produce identical results.
June 30, 2020 at 07:03 #28617Gordon01
ParticipantIf you do not want to spend time learning the autotools/Make internals, or porting the project from WSL to Windows-based build tools, please try importing the project as a Linux-based project built with external tools under WSL and make sure the manual build command line matches one that is already working. As long as both VisualGDB and the manual build are using WSL, they should produce identical results.
Thank you, this works easily.
But how do I debug and flash it?
June 30, 2020 at 07:34 #28620support
The easiest way to do this would be to use Embedded Quick Debug.
July 16, 2020 at 03:21 #28742Gordon01
ParticipantI’m getting ‘Frame not in module”
I think this is probably due to different path in the ELF file because it was compiled under WSL.
You must be logged in to view attached files.July 16, 2020 at 08:41 #28745support
KeymasterNo problem, you can configure the path mapping between GDB and VS as shown here: https://visualgdb.com/documentation/pathmapping/
July 16, 2020 at 16:37 #28746Gordon01
ParticipantThank you.
However, I’m still getting “Frame not in module”
Path in the ELF file looks strange:
— \mnt\c\Projects\pwr_meter\apps\pwrmeter\main.c —————————–
You must be logged in to view attached files.July 17, 2020 at 08:47 #28751support
The path mapping looks correct now. If the problem persists, please send us a screenshot of the problem along with a gdb log and we will help you understand what is going on.
August 19, 2020 at 03:09 #28863Gordon01
ParticipantI’ve attached a log file.
I wonder, could it be because “Quick debug” dialog doesn’t respect the project’s path mapping?
You must be logged in to view attached files.August 19, 2020 at 08:18 #28865support
KeymasterYes, Quick Debug has its own path mappings stored in the .quickdbg files under %LOCALAPPDATA%\VisualGDB\QuickDebugPresets.
You can edit the Quick Debug path mappings using the path mapping icon in the GDB Session window (item #3).
August 19, 2020 at 09:41 #28866Gordon01
ParticipantI’m getting this error after clicking “OK” in the “Edit Path Mapping” dialog.
But I have .quickdbg file under %LOCALAPPDATA%\VisualGDB\QuickDebugPresets
VisualGDB version: 5.5.7.3666
—————— System.ArgumentException ——————
System.ArgumentException: Settings file path not specified
в VisualGDB.VisualGDBProjectSettings2.SaveAsOrThrow(String settingsFilePath, Boolean updateCurrentFileName)
в VisualGDB.Add_In.Tool_Windows.WPF.GDBSessionToolControl.editMappings_Click(Object sender, RoutedEventArgs e)
trace=[VisualGDB.VisualGDBProjectSettings2.SaveAsOrThrow:21, VisualGDB.Add_In.Tool_Windows.WPF.GDBSessionToolControl.editMappings_Click:503]August 20, 2020 at 20:08 #28868support
KeymasterNo problem, please try this build: VisualGDB-5.5.8.3769.msi
August 29, 2020 at 04:37 #28921Gordon01
ParticipantThis build works!
Sorry for the late answer.
