Sysprogs forums › Forums › VisualGDB › OpenOCD Open Failed
- This topic has 4 replies, 3 voices, and was last updated 5 years ago by
July 6, 2018 at 01:20 #21277
mpm165
ParticipantHello all,
I am trying to get started with the STM32F7 Discovery board and have been following this tutorial: https://visualgdb.com/tutorials/arm/stm32/stm32f7/. I was following along and everything was fine until I went to “Test OpenOCD Settings” in step 7. I get the error message that the ‘Open failed’ with the following log:
C:\Users\MICHAE~1\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.openocd\bin\openocd.exe -c “gdb_port 51240” -c “telnet_port 51241” -f interface/stlink-v2-1.cfg -f target/stm32f7x.cfg -c init -c “reset init” -c “echo VisualGDB_OpenOCD_Ready”
Open On-Chip Debugger 0.10.0 (2018-05-24) [https://github.com/sysprogs/openocd]
Licensed under GNU GPL v2
For bug reports, read
WARNING: interface/stlink-v2-1.cfg is deprecated, please switch to interface/stlink.cfg
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
srst_only separate srst_nogate srst_open_drain connect_deassert_srst
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
Info : clock speed 1800 kHz
Error: libusb_open() failed with LIBUSB_ERROR_NOT_FOUND
Error: open failed
in procedure ‘init’
in procedure ‘ocd_bouncer’I have found similar issues but as this is the first time I am working on an embedded system outside of a classroom setting I am having trouble following solutions. I am using the most recent versions of VisualGDB and OpenOCD on Windows10 Pro-64. If anyone has any assistance I would greatly appreciate it.
Thank you,
Michael M.
July 6, 2018 at 01:31 #21278support
Please refer to the following page for instructions on troubleshooting this: https://visualgdb.com/support/nodevice
July 6, 2018 at 02:24 #21279mpm165
ParticipantGot it working, thank you very much.
September 26, 2021 at 07:06 #31383Reza1757
ParticipantI have similar problem, my code build correctly but in debug phase i have this problem.
C:\Users\REZA\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.openocd\bin\openocd.exe -c “gdb_port 49501” -c “telnet_port 49500” -f interface/stlink-v2.cfg -f target/stm32f1x.cfg -c “tcl_port 2048″-f” interface/stlink-v2.cfg -f target/stm32f1x.cfg -c init -c “reset” init” -c init -c “reset init” -c “echo VisualGDB_OpenOCD_Ready”
Open On-Chip Debugger 0.10.0 (2020-12-28) [https://github.com/sysprogs/openocd]
WARNING: interface/stlink-v2.cfg is deprecated, please switch to interface/stlink.cfg
tcl_port [port_num]how can i fixed it?
September 26, 2021 at 08:16 #31384support
