Sysprogs forums › Forums › VisualGDB › OpenOCD Issue
- This topic has 14 replies, 2 voices, and was last updated 9 years, 3 months ago by
December 25, 2016 at 22:52 #9850
sidprice
ParticipantI have a project I am trying to get started with debugging. The debug pod is an STLinkV2 and the target is a Nucleo-F401RE. My project builds correctly and when I start debugging GDBServer looks good:
Open On-Chip Debugger 0.9.0 (2016-10-14) [https://github.com/sysprogs/openocd]
Licensed under GNU GPL v2
For bug reports, read
hla_swd
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
none separate
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
Info : clock speed 1800 kHz
Info : STLINK v2 JTAG v23 API v2 SWIM v9 VID 0x0483 PID 0x374B
Info : using stlink api v2
Info : Target voltage: 3.239293
Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
adapter speed: 1800 kHz
stm32f4x.cpu: target state: halted
xPSR: 00000000 pc: 0x489fc31e msp: 0x0000000c
Info : Unable to match requested speed 8000 kHz, using 4000 kHz
adapter speed: 4000 kHz
VisualGDB_OpenOCD_ReadyHowever, GDB fails to connect to the target:
VisualGDB is licensed to Sid Price
C:\SysGCC\arm-eabi\bin\arm-eabi-gdb.exe –interpreter mi C:\DataRoot\Projects\bmp_windows_build\bmp_windows_build\VisualGDB\Release\app.elf
-gdb-version
=thread-group-added,id=”i1″
GNU gdb (GDB) 7.12
Copyright (C) 2016 Free Software Foundation, Inc.
This GDB was configured as “–host=i686-pc-mingw32 –target=arm-eabi”.
For help, type “help”.
Reading symbols from C:\DataRoot\Projects\bmp_windows_build\bmp_windows_build\VisualGDB\Release\app.elf…
done.
GNU gdb (GDB) 7.12
OK
-list-features
No symbol “disassembly” in current context.
-gdb-set print demangle off
OK
-break-insert -f main
^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x080014c8″,func=”main”,file=”main.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\main.c”,line=”35″,thread-groups=[“i1″],times=”0″,original-location=”main”}
set remotetimeout 60
&”set remotetimeout 60\n”
=cmd-param-changed,param=”remotetimeout”,value=”60″
OK
target remote :50048
&”target remote :50048\n”
&”:50048: No connection could be made because the target machine actively refused it.\n”
r7: Failed to connect to the debug stub
at l61.r(String a, g5 b)
at l61.y(IEnumerable`1 b, Boolean a)
at l61.i_2(DebugCustomizationSettings a)
at jb.h3()
at VisualGDB.GDBDebugEngine.o2(ry b, d a)Please advise how I can correct this,
Sid
This topic was modified 9 years, 3 months ago by
sidprice.
December 26, 2016 at 00:53 #9852support
Looks like a firewall or antivirus might be blocking the connection between gdb and OpenOCD.
Please try disabling it. If it does not help, please enable the diagnostic logging via View->Other Windows->VisualGDB Diagnostics Console and check if the gdb_port specified in OpenOCD command line matches the port used in the ‘target remote’ command.
December 26, 2016 at 16:55 #9853sidprice
ParticipantIn the GDBSession view I see:
&”target remote :49321\n”
&”:49321: No connection could be made because the target machine actively refused it.\n”
^error,msg=”:49321: No connection could be made because the target machine actively refused it.”In the VisualGDB diagnostics I see:
Launching gdbserver: C:\Users\Sid\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.openocd\bin\openocd.exe -f interface/stlink-v2-1.cfg -f target/stm32f4x.cfg -c “gdb_port 49321” -c “telnet_port 49320” -c init -c “reset init” -c “echo VisualGDB_OpenOCD_Ready”
There is no firewall enabled and Windows Defender “realtime protection” is turned off.
Sid
December 26, 2016 at 19:03 #9855support
Thanks for checking this. Both OpenOCD and gdb settings look correct, so it looks like some system component is preventing them from being connected. Normally OpenOCD should connect to the hardware and open a TCP port (49321 based on your log) allowing gdb to connect to it and get access to the hardware. However, despite the correct setting and matching ports, something is interfering with the connection.
To diagnose this further, please try running the OpenOCD command shown in the log from the %LOCALAPPDATA%\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.openocd\share\openocd\scripts directory. Once OpenOCD is running, start a new instance of arm-eabi-gdb.exe and type “target remote :49321” there.
If the problem reproduces, please try pinpointing it via the following steps:
- Instead of launching arm-eabi-gdb.exe and typing “target remote :49321”, please try running “telnet localhost 49321” (you may need to install telnet via Add/Remove Programs -> Windows Components). If this works, please try a different gdb binary.
- Alternatively please try changing the port to something below 10000 (e.g. 1234 instead of 49321).
- If none of the steps above help, please launch OpenOCD so that it opens the port 49321 and then run “netstat -a -b -n > list.txt” from an elevated command prompt and see if the output mentions OpenOCD listening on port 49321.
December 26, 2016 at 19:17 #9857sidprice
ParticipantAfter starting OpenOCD with the command from the log I started arm-eabi-gdb and typed “target remote:49321”, the response was:
C:\SysGCC\arm-eabi\bin>arm-eabi-gdb.exe
GNU gdb (GDB) 7.12
(gdb) target remote:49321
Remote debugging using :49321
warning: No executable has been specified and target does not support
determining executable automatically. Try using the “file” command.
0xfffffffe in ?? ()
(gdb)December 26, 2016 at 19:27 #9858support
Thanks for checking this, looks like the problem might be caused by the port auto-detection mechanism used by VisualGDB. Please try editing your .vgdbsettings file as follows:
<DebugMethodID>com.sysprogs.arm.openocd</DebugMethodID> <DebugMethodProperties> <Entries> <...> <KeyValue> <Key>com.sysprogs.arm.openocd.gdb_port</Key> <Value>1234</Value> </KeyValue> </Entries>
This should force VisualGDB to use the port 1234 for connection between OpenOCD and gdb. If this solves the problem, please check if port 49321 would also work when specified manually. If yes, it can be some weird conflict between VisualGDB opening and immediately closing the port to test it and OpenOCD using it to accept connections. If you can confirm this, we will add a workaround to our OpenOCD package.
December 26, 2016 at 19:39 #9859sidprice
ParticipantTHis gives the same result, the connection fails. The gdb_port added manually is being used when starting OpenOCD:
Launching gdbserver: C:\Users\Sid\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.openocd\bin\openocd.exe -f interface/stlink-v2-1.cfg -f target/stm32f4x.cfg -c “gdb_port 1234” -c “telnet_port 49862” -c init -c “reset init” -c “echo VisualGDB_OpenOCD_Ready”
December 26, 2016 at 20:36 #9861support
Thanks for confirming this. When VisualGDB displays a message about connection failure, does it offer a ‘retry’ option? If yes, does it work? If no, are you using the latest v5.2?
December 26, 2016 at 20:51 #9863sidprice
ParticipantYES!!! Using retry the connection is good and the target stops at start of main.
December 26, 2016 at 20:51 #9864sidprice
ParticipantIs this a clue … Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1219). Workaround: increase “set remotetimeout” in GDB
December 26, 2016 at 21:32 #9865support
The remotetimeout should not affect the initial connection problems.
Could you try locating the %LOCALAPPDATA%\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.openocd\edp.xml file and increasing GDBServerDelay to 5000 or even more? Perhaps OpenOCD initialization takes longer than the 2 seconds that VisualGDB waits normally?
December 26, 2016 at 21:40 #9866sidprice
ParticipantWith GDBServerDelay set to 5000 VisualGDB starts correctly.
However, it operates VERY slowly. A view opens saying the “Load” is taking too long and then if I try to step a line it tales 3-4 seconds to complete, this seems very slow.
Sid
December 26, 2016 at 22:04 #9867support
Are you using a VM with USB virtualization? If yes, slow debugging is to be expected. Please try running VisualGDB directly to get the best performance.
December 26, 2016 at 22:16 #9868sidprice
ParticipantYes I am running in a VM, I have another debugger that uses STLinkV2 and it does not have this speed issue! I cannot run the tools on the host PC because clients require delivery of software in a VM.
This reply was modified 9 years, 3 months ago by
sidprice.
December 26, 2016 at 22:39 #9870support
Sorry, perhaps the other debugger is handling some USB requests differently. VisualGDB relies on OpenOCD to handle low-level debugging and we can confirm that it does not work very fast on VMs. Hence our best advice is to use a physical VM instead (or at least run OpenOCD on a physical machine, however that would require a complex manual setup).
