nrf52 hardfault_handler_gcc is not added to project
Sysprogs forums Forums VisualGDB nrf52 hardfault_handler_gcc is not added to project
  • #29495
    wtywtykk
    When the hardfault option in nRF5x Libraries is enabled, hardfault_handler_gcc.c should be added. Currently it’s missing so this module doesn’t work.
    #29518
    Thanks, we have fixed it on our side and will include the fix in the next BSP release. As the issue is very minor and has an easy workaround, we will not make a separate release until we discover other issues with the current BSP, or a newer SDK is released.
    You can patch it on your side by applying the following patch to %LOCALAPPDATA%\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nordic.nrf5x\BSP.XML:
    --- bsp.old	2020-10-12 19:57:10.832588900 -0700
    +++ BSP.XML	2020-11-16 16:19:10.049551300 -0800
    @@ -158561,6 +158561,7 @@
             <string>$$SYS:BSP_ROOT$$/nRF5x/components/libraries/gfx/nrf_gfx.c</string>
             <string>$$SYS:BSP_ROOT$$/nRF5x/components/libraries/gpiote/app_gpiote.c</string>
             <string>$$SYS:BSP_ROOT$$/nRF5x/components/libraries/hardfault/hardfault_implementation.c</string>
    +        <string>$$SYS:BSP_ROOT$$/nRF5x/components/libraries/hardfault/nrf52/handler/hardfault_handler_gcc.c</string>
             <string>$$SYS:BSP_ROOT$$/nRF5x/components/libraries/hci/hci_mem_pool.c</string>
             <string>$$SYS:BSP_ROOT$$/nRF5x/components/libraries/hci/hci_slip.c</string>
             <string>$$SYS:BSP_ROOT$$/nRF5x/components/libraries/hci/hci_transport.c</string>
    \ No newline at end of file
