nRF Connect SDK v2.7.0
Sysprogs forums Forums VisualGDB nRF Connect SDK v2.7.0
  • #35766
    x_ruslan
    When creating an nRF Connect SDK v2.7.0 project, the boards are not displayed. Please help me!
    Thanks in advance!
    #35768
    No problem, we have reproduced and fixed the issue. Please try this build: VisualGDB-6.0.103.5197.msi
    #35770
    x_ruslan
    Thank you!
    #35771
    x_ruslan
    There is still a problem with the device through the tab. (((
    #35772
    Sorry, not sure what you meant. If you believe VisualGDB is not working correctly, please provide complete screenshots showing every step of the wizard, and every other step you take (e.g. changed settings), including the final error message you get. Please ensure the screenshots are complete and uncropped. A single error message taken out of context is often not enough to suggest anything meaningful.
    #35778
    x_ruslan
    Screenshots
    #35786
    Thanks, this looks like the device type auto-detection wasn’t working due to another change in the SDK structure, although selecting it manually would still work.
    We have fixed it in this build: VisualGDB-6.0.103.5201.msi.
