Not running debugging (Live Variables) through J-Link
Sysprogs forums › Forums › VisualGDB › Not running debugging (Live Variables) through J-Link
Viewing 15 posts - 1 through 15 (of 24 total)
  • #8466
    u37
    Segger provided an opportunity to rework the official ST-Link in your J-Link (https://www.segger.com/jlink-st-link.html).This debugger works well in Keil and other programs, but VisualGDB gives errors. In the derivation of “Live Variables” information is incorrect, the rate of output incorrect (too fast), the normal rate of 200-900 samples / sec.
    If you put a normal (original) debugger – ST-Link, J-Link – the information is displayed correctly.
    How can I fix the work VisualGDB?
    [URL=http://saveimg.ru/show-image.php?id=7631099d756c984b8e758ffbc7328179] [IMG]http://saveimg.ru/thumbnails/21-06-16/034cb122544fa33a0492cfbf5f1c8ed2.png[/IMG][/URL]
    #8468
    Please update your J-Link EDP to v3.2 via Tools->Embedded Tools Manager. This should fix the problem.
    #8469
    u37
    Unfortunately, version 3.2 has been installed. But, I bet again:
    http://saveimg.ru/show-image.php?id=a1c095381a788e6ce36dd47a84bab722
    #8471
    Thanks for checking this. Could you please try this diagnostic build: http://sysprogs.com/files/tmp/VisualGDB-5.2.4.880.msi
    Then replace the %LOCALAPPDATA%\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.segger-dmsp\SeggerEDP.dll file with this one: http://sysprogs.com/files/tmp/SeggerEDP.dll
    Finally start your debug session and open the View->Other Windows->VisualGDB Diagnostics Console window. It should show what exactly the Segger memory reading API returns. Please let us know what is shown there so that we could fix this.
    #8472
    u37
    No changes. ((
    Additional Information.
    If you stop the program, take the variable Live Variables (eg Tst0) and write 0 to it (any value), then ALL other variables will be the =correct= value. These values correspond to what is in the memory (window = memory, region 0x20…58C / 590 / …)
    After continuing execution Live Variables do not change.
    JLINKARM_ReadMemEx(0x20000590, 4) returned 4
    JLINKARM_ReadMemEx(0x20000594, 4) returned 4
    JLINKARM_ReadMemEx(0x20000598, 4) returned 4
    JLINKARM_ReadMemEx(0x2000058c, 4) returned 4
    #8473
    OK, please try this version http://sysprogs.com/files/tmp/SeggerEDP.dll
    It will also show the data received from JLINKARM_ReadMemEx().
    #8474
    u37
    1. All missing variables in the “Live variables”
    2. These variables can be added to the “Visual Watch”
    3. These variables can not be added to the “Live variables”
    http://saveimg.ru/show-image.php?id=fa40bd0c86146aa8a0fa98906ee228b4
    Translation error text: “The index is outside the bounds of the array.”
    #8477
    Sorry, does the latest build cause this when adding the same variable as before, or are you trying something completely different?
    #8478
    u37
    Step 1: Replace SeggerEDP.dll
    Step 2: When the project is opened there is a lack of variables in the “Live Variables”
    Step 3: my variables (are the same that were before) can not be added to the section “Live Variables”. In principle, it is impossible – the error window appears.
    #8479
    u37
    VisualGDB v5.2 b882: No changes. ((
    #8480
    u37
    Switch debuger to “STLink” mode:
    0x20000598: 00003cb1
    0x20000590: 00007965
    0x2000058c: 00000001
    0x20000594: 0000009c
    0x20000598: 00003cca
    0x20000590: 00007997
    0x20000598: 00003ce4
    0x20000590: 000079c9
    0x20000594: 0000009d
    0x20000598: 00003cfd
    0x20000590: 000079fd
    0x20000598: 00003d17
    0x20000590: 00007a33
    0x20000598: 00003d30
    0x20000590: 00007a67
    0x20000598: 00003d4a
    0x20000590: 00007a9d
    0x20000594: 0000009e
    0x20000598: 00003d63
    0x20000590: 00007acf
    #8481
    u37
    Without leaving the Visual Studio project to alter debugger “JLink” mode and run debugging:
    – The window “Live variables” disappear my variables, add impossible (an error occurs).
    (Problem described previously.)
    #8485
    Sorry, looks like a bug in the debug build. Please try this one: http://sysprogs.com/files/tmp/SeggerEDP.dll
    #8487
    u37
    Add the entire program RAM recording counter in the left’s capacity 0x55aa cells.
    In “Live Variables” read the same garbage (0x55AA).
    http://saveimg.ru/show-image.php?id=9059867313736ca9c679c49aeb472190
    #8488
    OK, this means that the incorrect values are coming from the J-Link software. Please try installing the latest version of it, installing the latest firmware to your J-Link and reducing the JTAG frequency.
    If this does not help, please try contacting Segger support with the log showing what JLINKARM_ReadMemEx() returns, perhaps they have a better idea why it is returning incorrect data.
