Not possible to "source" bash script
Sysprogs forums › Forums › VisualGDB › Not possible to "source" bash script
  • #10097
    hfrmobile
    I have to call some bash scripts on the remote machine after building but it is not possible to “source” bash script in VisualGDB:
    • . script1.sh
    • script2.sh
    • script3.sh
    “Sourcing” the script1.sh is necessary because the other scripts need environment variables set/changed by the first script.
    Workaround: I created a “runall.sh” which does the lines above.
    Not sure if this is by design but caused me hours of  error search …
    #10104
    This is by design. Each command is started in a separate SSH channel, so the previous commands won’t affect the next ones. This is by design as otherwise unforeseen side effects from some commands executed early could cause very hard-to-diagnose bugs later.
