No debugging logs from win32 applications in vista or seven
Sysprogs forums Forums VisualDDK/VirtualKD discussion No debugging logs from win32 applications in vista or seven
  • This topic has 5 replies, 4 voices, and was last updated 13 years ago by Hex.
  • #482
    I’ve noticed that there’s a problem, when debugging via virtualkd – no application logs can be seen in windbg. I mean if application is using OutputDebugString() it’s not shown in windbg session. Nevertheless DbgPrint() messages from drivers are shown. I already have “Debug Print filter” set to 0xFFFFFFFF in the registry, so it’s not the issue. And I’ve checked, the logs are shown if you use original \pipecom_1 instead of virtualkd boot entry.
    #2212
    Hex
    Any chance to fix that?
    #2214
    That’s the default behavior in Windows Vista and later. Please have a look here: http://www.osronline.com/article.cfm?article=295
    #2216
    Hex
    @bazis wrote:
    No it’s not, because, as I’ve written before, I can see all messages in windbg if I switch back to \.pipecom_1.
    #2215
    Fixed in 2.8
    #2213
    broken850
    restoring to a snapshot of a VirtualBox Win7-x86 machine without VirtualKD, connecting with a serial kernel debugger to com1 on the target — assert works as expected, and it asks whether to Break/Ignore/etc. This is without Service Pack 1, so perhaps it is only the default behavior on SP1?
